clemo2k1 Posted January 1, 2009 Posted January 1, 2009 evening all does the last overspill pipe from the injector closest to the bulkhead dissapear down the back of the engine on a 300 tdi i just noticed today than mines not there wondered if it had fell down the back coz ive had all the turbo pipes off trying to fix another problem Quote
Guest DiscoTD4 Posted January 1, 2009 Posted January 1, 2009 Hi - mines blanked off and does not have a pipe connected, which I think is normal. It looks like it should have a pipe as there is a small stub, made me look twice the first time I saw it Cheers Quote
clemo2k1 Posted January 2, 2009 Author Posted January 2, 2009 i have found a pipe that looks like it should go on which dissaperes down the back of the engine but seems a bit short and is loose fittingwhen i stretch it to go on ill try to add a pic today Quote
StevenA Posted January 2, 2009 Posted January 2, 2009 i have found a pipe that looks like it should go on which dissaperes down the back of the engine but seems a bit short and is loose fittingwhen i stretch it to go on ill try to add a pic today The end of the spill line is blanked off, although it does not look obvious without closer inspection - there is no pipe to go here - the return is via the injection pump. The pipe that you have found sounds like the breather pipe from the transfer or gear box and should end in a curve behind the engine. Quote
clemo2k1 Posted January 2, 2009 Author Posted January 2, 2009 chrres lads prpoblem solved allthough in essence there was no problem Quote
