unclebill1 Posted January 2, 2009 Posted January 2, 2009 Hi, OK dumb moment of the new year, pulled the fuse on the air suspension by mistake whilst the engine was running, hence I now have the air suspension fault up on the dashboard. Don't think its possible, but is there a trick way to reset the EAS without the magic box, I've disconnected the battery and am going to leave it overnight, but I suspect that will do nothing. If not its visit to the garage Monday morning. Cheers Bill Quote
paintman Posted January 2, 2009 Posted January 2, 2009 There's a lot of info in http://www.rangerovers.net/repairdetails/a...sion/index.html whether there's anything there that might help you? Quote
RangeyRover Posted January 2, 2009 Posted January 2, 2009 http://www.rangerovers.net/repairdetails/a...arsoftware.html Looks very interesting for clearing faults for your suspension Quote
unclebill1 Posted January 2, 2009 Author Posted January 2, 2009 http://www.rangerovers.net/repairdetails/a...arsoftware.htmlLooks very interesting for clearing faults for your suspension Thanks guys, pair of interesting links. Better put the sensible head on for tomorrow and put the hammer and chisel away. Cheers again Bill Quote
Escape Posted January 3, 2009 Posted January 3, 2009 As far as I know, no one has yet found a way to clear the fault with jumpers. You can however use jumpers to activate the EAS, as explained on the sites mentioned above. Only way to read and clear faults is with a Testbook of some sort or the EAS-software on a computer with serial/OBD cable. Quote
