Posted
8274 wired up with albrights.
was powering in the rope after cleaning it from the weekend and noticed a spark between the drum and the nut of one of the mounting bolts. it did it once each time the motor was engaged. after doing it 3 times the winch stopped. solenoids just clicked. i rotated the drum slightly by hand and then it all worked again with no sparks as expected.
so my guess is that the motor (Bowmotor) shorted somewhere and passed the current through the gears to the drum which then earth on the nuts is this feasbile and why would it do it?
i checked the earth strap and all good no problems i could see there.
the wiring setup for it goes back to the albrights then straight to the battery and hasn't been changed for a long time and never used to be a problem.
any thoughts
Posted
If it's an old/well used motor it's possible that debris/dust from the brushes and commutator has built up and is providing a path to the metal of the armature/spindle of the motor. Theoretically this could then find it's way through the gears to the drum which is electrically isolated from the case by the nylon bushes it runs on.
It could also be caused by an insulation breakdown in the armature windings although dust is more likely. It's worth cleaning the dust out of the motor at regular intervals anyway as it will prolong the life of the motor.
Posted
with it being my motor dust is a likely hood, but the motor is almost new has done less than 100 pulls i expect.
so pull the motor and have a look i guess.
Posted
As Tony says above , I had it on your 2 dayer on the sunday , On top of the bowl in the quarry , The thing stopped altogether , Found out the terminal was loose on the winch batteries , Only found this out because it started working again after I washed it and sparks were jumping from the mounting bolts .
Posted
stripped the winch today, some car*p in the bottom of the the end (furtherest from the winch body) so cleaned up and refitted, fingers crossed time will tell,
decided not to do much winching with it as the Dyneema was still frozen on from yesterdays DRD!
Posted
I am sure JST won't bear a grudge / send you into a punch from hell in the future :rolleyes: as revenge.............
It's alright Nige, i'll send him into the deep, cold water for no real reason. :P
Posted
Lack of use I expect. :ph34r:
i was about to say you are right Nick, lack of use and build up of condensation
but now i think i may just have a groin strain coming on about 14 Mar..................
