titan Posted January 2, 2009 Posted January 2, 2009 ok disco fuel gage was working but after i filled it up it sat on empty and has stay there with the light on since so any ideas or quick fix solution to this when i test drove it it was sitting just above empty this only happends once i filled it up i take it the float is stuck or broken any help much needed (its a 300tdi) Quote
jimmy_neutron Posted January 2, 2009 Posted January 2, 2009 ok disco fuel gage was working but after i filled it up it sat on empty and has stay there with the light on since so any ideas or quick fix solution to this when i test drove it it was sitting just above empty this only happends once i filled it up i take it the float is stuck or broken any help much needed (its a 300tdi) I had this on a defender. Was the sender in the tank. You may find that it reads empty when full to the brim and when empty, and reads ok when you have used some fuel out of the tank. This would be due to the copper track on the sender being worn out. Quote
titan Posted January 2, 2009 Author Posted January 2, 2009 awsome well i figured i would run it for a few days and see if it sorts it self out if not then ill take other action Quote
pinny Posted January 2, 2009 Posted January 2, 2009 awsome well i figured i would run it for a few days and see if it sorts it self out if not then ill take other action in the boot under the carpet there is a cover held on by six self tappers remove these and it will expose the sender unit check its all connnected is this the disco from the hythe Quote
titan Posted January 2, 2009 Author Posted January 2, 2009 in the boot under the carpet there is a cover held on by six self tappers remove these and it will expose the sender unit check its all connnected is this the disco from the hythe yes m8 cause of the deal i have no come backs but not botherd it wont be a hard job :unsure: i hope will have a look tomorro cheers m8 Quote
pinny Posted January 2, 2009 Posted January 2, 2009 yes m8 cause of the deal i have no come backs but not botherd it wont be a hard job :unsure: i hope will have a look tomorro cheers m8 youll prob find there a pain to get out i used mole grips to undo mine and covered them in grease when i put it back if you want to borrow a grease gun to grease your ujs let me know ive got plenty of grease Quote
titan Posted January 2, 2009 Author Posted January 2, 2009 youll prob find there a pain to get out i used mole grips to undo mine and covered them in grease when i put it back if you want to borrow a grease gun to grease your ujs let me know ive got plenty of grease funny old thing my grease gun has broken send me a pm let me no where you are i could do with someone else having a look over it see if i missed out Quote
pw8757 Posted January 2, 2009 Posted January 2, 2009 And the good news is that whilst you are looking at the fuel gauge sender, you'll also be in a position to look at the rear floor pan and treat the rust before it takes hold....... (As I found this week when I took out the carpets to fit a DAB radio Ariel.................) Quote
titan Posted January 2, 2009 Author Posted January 2, 2009 And the good news is that whilst you are looking at the fuel gauge sender, you'll also be in a position to look at the rear floor pan and treat the rust before it takes hold.......(As I found this week when I took out the carpets to fit a DAB radio Ariel.................) good point i only had a quick snoop around there first job on list tomorro cheers Quote
pinny Posted January 2, 2009 Posted January 2, 2009 good point i only had a quick snoop around there first job on list tomorro cheers did you get me phone no gis a ring when you get time Quote
titan Posted January 2, 2009 Author Posted January 2, 2009 did you get me phone no gis a ring when you get time no m8 i pm'd you Quote
