Posted
On my Disco 200TDI Auto I have now got an odd clunking noise when reversing slowly, it seems to come from the rear. it seems to be get worse. Has anyone had this before, not sure if to start looking at the axle or gearbox.
Thanks.
Posted
Start by checking the rear A-frame ball joint. Common source of clunks from the back. Use a lever between the frame & the top of the axle by the ball joint to lever the two apart. Should be little if any movement.
