Dazza Posted January 3, 2009 Posted January 3, 2009 Hi All Got a bit of a weird question I need to find the hose that goes between the airfilter housing and the engine (the 3 inch diamater piece) as mine has broken, the problem i have got is i dont know what it is called and i cannot find it on the web. Please HELP Quote
BogMonster Posted January 3, 2009 Posted January 3, 2009 I'd call it air intake ducting but I don't know what the Land Rover part name is, probably something stupid that you would never think of typing into Google as that is what they normally do. Somebody with a copy of Microcat will no doubt be along with a part number for you in due course. Quote
western Posted January 3, 2009 Posted January 3, 2009 Somebody with a copy of Microcat will no doubt be along with a part number for you in due course. the large diameter hose from air filter case to turbo intake is ntc7803 for Discovery 200Tdi vehicles. Quote
Dazza Posted January 4, 2009 Author Posted January 4, 2009 the large diameter hose from air filter case to turbo intake is ntc7803 for Discovery 200Tdi vehicles. Its a v8 efi so no turbo Quote
ste clark Posted January 4, 2009 Posted January 4, 2009 where about in the world are you?? i have a whole 200tdi doing nothing on the drive.. if you are local you can have the pipe!! Quote
JimAttrill Posted January 4, 2009 Posted January 4, 2009 Dazza, I suggest you change your sig to show what LR you own, then you don't have to tell us. And some indication of where you are in the world makes a big difference to the answers you will get. Cheers, Jim Quote
Dazza Posted January 4, 2009 Author Posted January 4, 2009 Dazza, I suggest you change your sig to show what LR you own, then you don't have to tell us. And some indication of where you are in the world makes a big difference to the answers you will get. Cheers, Jim Thanks for the pointer I am in Hampshire Quote
teabag Posted January 4, 2009 Posted January 4, 2009 ESR1611L Hose-flexible for disco's upto Vin VA081991 that will be 3.5 V8 round air filter. ESR1807 Hose-duct to throttle body from Vin MA 08991 and MA 112195 3.9 V8 square air filter. http://www.paddockspares.com/search.asp http://www.rimmerbros.co.uk/ ESR1611L £41.80 at Rimmers Quote
FridgeFreezer Posted January 4, 2009 Posted January 4, 2009 You can buy it by the metre from Hyphose. It's Wyrem flexible ducting you want and costs about £20 per metre last time I bought any. You may need a "top hat" adapter piece if the diameters are different (from memory they are), but worth a look before splashing out £40+ to Rimmers. Failing that, Martin Toole at Nursling Southampton will have one, 07885 399785. Quote
pw8757 Posted January 4, 2009 Posted January 4, 2009 I got ESR1807 from Ripon Land Rover on181208 for £13-81 inc VAT. They had to get it in overnight because they don't carry them. I expect your local dealership can do the same........... Hope that helps........... Quote
teabag Posted January 5, 2009 Posted January 5, 2009 I got ESR1807 from Ripon Land Rover on181208 for £13-81 inc VAT. They had to get it in overnight because they don't carry them.I expect your local dealership can do the same........... Hope that helps........... Rimmer's price is £13.05inc VAT so ESR1807 it's the cheapest of the two hoses, strange that Quote
