Posted
hi all.
As many of you are, i am currently trying to warm up the interior of my 90, its 200tdi with electric fan, so should warm up quite well, when sat stationary it does, but when on general road use the heater doesnt seem to do much. All cables are adjusted as they should be. I have wing top air scoops which 'ram' the air in to the heater, is this what is causing my heater to be so cold?
Posted
which thernostat is fitted, it should be a 88 degree anything less will affect how much heat the cooling/heating system can push into the cab.
Posted
How do you tell which thermostat you have?
I fitted a wing top 'scoop' vent, but can't decide if it really makes any difference - that probably means it doesn't!
Posted
im not entirely sure as ive never had it appart, may be worth a look. i just thought that the cold air rushing in to the heater matrix surely efects the temparature?
Posted
The wingtop scoop is supposed to increase airflow though the heater and push more air into the cab thus improving cab temperature - I had one on my 90 and it made no difference..............
Paul
Posted
hi all.
On my 1988 90" fitting an air scoop made a tremendous difference. Much more hot air and much less noise.
Mine is the cheapest of cheap air scoops, the £8+vat model LR106R from Paddock
Posted
:unsure: Don't mean to be OT but does water get into the footwells through the air scoop? The air scoop on mine made a big difference with air intake!! :huh:
Posted
sounds like i should probably be look elsewhere for the problem, il take the thermostat out this weekend and have a look at that, and try and seal most of the holes in the cab area,.
cheers
Posted
cheers
It would be worth putting in a new one at the same time as they cost about £2 and can wear out and open too early, too late, stick open etc. You may as well start with a decent one.
Chris
Posted
I've had a wing top scoop on mine for a while, doesn't really seem to make much difference though, maybe a slight improvement if travelling at a decent speed but when stopped or going slowly it only hinders the flow as others have said.
The other side issue is though, as Hamish Grundy has suggested, even if it does increase airflow, ie. at speed, this could reduce the heater matrix temperature if it's not getting hot enough to start with so you end up with no real benefit anyway.
Always good for wetting your passengers feet if you go wading a bit deep and the bow wave comes over the bonnet/wings, best to shut it off first.
Posted
fitted to the heater intake air duct is a rubber one way valve, IIRC it can be accessed with the bonnet open, it works the same way as the similar valve on the engine air cleaner case, give it a squeeze & a clean out, that should stop any water reaching the dash ducting & getting onto the floor.
Posted
Depends how quickly the water comes in, a bit of rain water is OK but it can't cope with a proper gush.
Thinking about sticking a second snorkel on mine.
