Posted
Hi
The heater on my 110 has died. Being a V8 its not so much of a problem once its warmed up, however as its the fan that appears to have gone i cant demist the windows, not so much fun in the rain. I'v checked all the cables and all appear to be working and the resistance across the motor doesnt seem to bad and it spins freely. Are there any inline fuses other than the main fusebox or any other checks i can try before i take the dash and the matrix apart. Its a 1985 CSW 3.5 V8 on carbs if thats any help.
Regards
Tom
Posted
you could check the purple wire thats if its purple for a 12volt supply with ignition on,the other wire is a variable earth via the switch
ignore the writing on the picture
