wheatfielder Posted January 7, 2009 Posted January 7, 2009 Can one replace the large nobbly grommet bit on the indicator stalk (1991 defender) without taking off the stalk ? or do you have to buy/ replace the whole switch unit? Cheers all, happy new year - hope it gets better as I have a slipped disc, great start to the year!! Quote
western Posted January 7, 2009 Posted January 7, 2009 rubber gaiter is not available as a seperate part, only fix is to live with it in a tatty state or completly replace the stalk assembly [expensive] Quote
wheatfielder Posted January 7, 2009 Author Posted January 7, 2009 rubber gaiter is not available as a seperate part, only fix is to live with it in a tatty state or completly replace the stalk assembly [expensive] I took it off altogether now Ralph and just left a hole, could that cause a problem? cheers. Quote
western Posted January 7, 2009 Posted January 7, 2009 only if you drop something metallic in there & it shorts out on the terminals. Quote
bishbosh Posted January 7, 2009 Posted January 7, 2009 A pattern part is not too expensive - £25 ish I think. The pain is that you have to take the steering wheel off to change it (again, I think!) Quote
Cat_J Posted January 7, 2009 Posted January 7, 2009 But once the wheels off its an in and out job. Quote
