Hamish Grundy Posted January 9, 2009 Share Posted January 9, 2009 i have biult a 300tdi auto 80'' trialer, i have used a rear rad set up to spread wieght, should the water pump be man enough to pump the water around the system? i am having trouble getting the top hose warm, the bottom hose warms fine but the top remains cold. any sugestions would be a help!! cheers, hamish Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted January 9, 2009 Share Posted January 9, 2009 i did it with a friends RR V8 couldn't keep it cool i'd put a pump in http://www.demon-tweeks.co.uk/products/sea...p;x=13&y=11 I'm shore you could get it cheaper from somewere elce Quote Link to comment Share on other sites More sharing options...
landmannnn Posted January 9, 2009 Share Posted January 9, 2009 i have biult a 300tdi auto 80'' trialer, i have used a rear rad set up to spread wieght, should the water pump be man enough to pump the water around the system? i am having trouble getting the top hose warm, the bottom hose warms fine but the top remains cold. any sugestions would be a help!!cheers, hamish It can work without an electric pump. You have to be spot on with bleeding air out though, have you got the expansion tank above the rad? Quote Link to comment Share on other sites More sharing options...
Hamish Grundy Posted January 9, 2009 Author Share Posted January 9, 2009 It can work without an electric pump. You have to be spot on with bleeding air out though, have you got the expansion tank above the rad? yeah, its half way up the rear stay. i was thinking that i might park it on a bank 2moro and try again. i dont realy want the espense of an electric water pump. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted January 9, 2009 Share Posted January 9, 2009 I had twin rads on my old 3.9 hybrid V8. one in the front (BIG V8 rad) and a second rad on the down rails of the rear cage plus twin fans all ok from std pump The increase in fluid quantities alone was near double so made a massive difference Nige Quote Link to comment Share on other sites More sharing options...
Hamish Grundy Posted January 10, 2009 Author Share Posted January 10, 2009 does any one know if warm water should go in the bottom or top of the radiator?? Quote Link to comment Share on other sites More sharing options...
alfredenewman Posted January 10, 2009 Share Posted January 10, 2009 it goes in hot at the top cools as it goes through and down the rad and out via the bottom hose i think you are air locked somewere carry on trying different bleeding methods good luck Quote Link to comment Share on other sites More sharing options...
Hamish Grundy Posted January 10, 2009 Author Share Posted January 10, 2009 right....ive been driving it most of the afternoon and all seems well at the moment, altho i have an oil leak at the pas pump and is causing the belt to slip. if it was going to get hot it probably would have by now wouldnt it? any one got a wide angle prop forsale?? Quote Link to comment Share on other sites More sharing options...
