Discovery heads??
loonylandy
After a recent head gasket change it would appear i have a cracked head which now means my truck is dead !!! :(
Been looking at the options and the rest of the disco is sound, no or little rust and very good condition, so now i need to think what to do :unsure:
If i bought a new head like this http://turner-engineering.co.uk/html/specialoffers.html will this just bolt on and job done or will i need to do anything else ???
cheers
tony
It's a 300TDi, Jim...
Tony - you will need to build up the head with the valves, rocker gear etc, but other than that it should bolt straight on. If you drop Mark a PM (Mark is his user and actual name...), he had a new head from Turners last year for exactly the same reason and will be able to tell you exactly what you'll need to do.
Come to think of it, so will Turners...
Laters
Adrian
cheers
tony
Tony, I learned the hard way, replaced the head gasket, skimmed the head, had it pressure tested; after removing the head three times I bought a new one, had the valves seated, and no more problems.
My advice, if the head plays up close to the 200 000 km distance, replace, do not repair.
