Stu2985 Posted January 17, 2009 Share Posted January 17, 2009 My 300 tdi auto box dipstick keeps working its way up the pipe After a coupe of days around 50 miles it creeps about a 1cm up breaking the seal at the top Any ideas ? the little clips dont look too worn where the dipstick kind of locks into the pipe Quote Link to comment Share on other sites More sharing options...
Delta Posted January 17, 2009 Share Posted January 17, 2009 My 300 tdi auto box dipstick keeps working its way up the pipeAfter a coupe of days around 50 miles it creeps about a 1cm up breaking the seal at the top Any ideas ? the little clips dont look too worn where the dipstick kind of locks into the pipe If u try to tighten the upper part of the pipe into an oval shape, gently using some pliars , your dipstick will stay locked. Just press 1mm and it will be enough. Fred Quote Link to comment Share on other sites More sharing options...
janderson41 Posted January 29, 2009 Share Posted January 29, 2009 Hi, a trick i was shown and use on my 1996 300Tdi auto is to tape down the dipstick onto the tube. was given this by an old land rover owner. keeps the dipstick in place. cheers Jim A. Quote Link to comment Share on other sites More sharing options...
Stu2985 Posted January 30, 2009 Author Share Posted January 30, 2009 My 300 tdi auto box dipstick keeps working its way up the pipeAfter a coupe of days around 50 miles it creeps about a 1cm up breaking the seal at the top Any ideas ? the little clips dont look too worn where the dipstick kind of locks into the pipe thanx for the replies guys will try em out this weekend (long as it dont snow ) Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted January 31, 2009 Share Posted January 31, 2009 Chances are the filter is getting blocked. Quote Link to comment Share on other sites More sharing options...
Stu2985 Posted January 31, 2009 Author Share Posted January 31, 2009 hmm - could you expand on that one a little bit mroe please Jim Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted January 31, 2009 Share Posted January 31, 2009 I have found that auto boxes build up pressure inside if the filter is not changed. This causes the dipstick to blow out. Quote Link to comment Share on other sites More sharing options...
Thys Posted January 31, 2009 Share Posted January 31, 2009 I have found that auto boxes build up pressure inside if the filter is not changed. This causes the dipstick to blow out. Jim, new filter, new ATF, autobox dipstick still moves up, can a blocked breather cause the pressure build-up, and if so, where is the breather located? Cheers, Thys Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted February 1, 2009 Share Posted February 1, 2009 Hi Thys, it is important to check that the filter you fit is the same as the one that comes out, and is the correct one. We were once supplied with a filter for a Jag or BMW (by ZF themselves, the idiots) which had a slightly different position for the inlet (or outlet) hole. It just about blew the whole dipstick out of the tube, and most of the oil as well. To tell you the truth, I don't know if the auto box even has a breather. Someone must know. The Disco II doesn't even have a dipstick so surely that one must have a breather somewhere. I'll have a look in the book of words and see if there is mention of one. Quote Link to comment Share on other sites More sharing options...
eddyoz Posted February 1, 2009 Share Posted February 1, 2009 Thys I have exactly the same problem.Atf and filter were changed last year,all works smoothly but auto dipstick moves out of its tube about 1cm after a short run.I suspected the breather which I think is on the left rear of the box[banjo fitting nylon pipe]The pipe disappeared over the bell housing somewhere too hard to locate,so left it as is!Only other quirk is sometimes the idle surges, probably only +/- 50 rpm.This is on a 300TDI auto,do not know if this related?Pressure etc. Quote Link to comment Share on other sites More sharing options...
Thys Posted February 1, 2009 Share Posted February 1, 2009 Hi Thys, it is important to check that the filter you fit is the same as the one that comes out, and is the correct one. Good afternoon Jim, and thanks for the reply. I did the bottom end service myself, no extra hands, so by the time I removed the cross member and one mounting to access the last sump bolt, I triple checked the new filter, unless of course the previous filter was also the wrong one. I must admit, after fitting the new filter and fresh ATF (drained and replaced twice at 100km intervals to allow for the ATF in the torque converter) I had a 100% improvement. The filter and gasket I bought from Wayne. Cheers Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted February 1, 2009 Share Posted February 1, 2009 It's a very good idea to change the ATF often, as you have done. If you want your gearbox to last, you could try Dexron III synthetic ATF (if you can find it). We used to use Shell Donax TX (not TA which is Dexron II red stuff), but it has been unobtainable for about a year now. And don't tow any horseboxes Quote Link to comment Share on other sites More sharing options...
