Indicator Lens and MOT question
Ebay, only a few quid.
Mine didn't on my first MOT and they didn't notice but it was working since and I did notice that they tested it last time so best make it work to be on the safe side.
EDIT: Nice one Les, I was too slow anyway.
A wing indicator is called a side repeater. You can buy them from most motor factors - if you can't get the same as your old one, then as long as it's fitted and working and secure, then it'll pass. Rear wash/wipe isn't a testable item.
Les.
although, if you remove the rear wiper and replace it with a spark plug, it will fail!
and i didnt do that for a the record!
