reggie Posted January 24, 2009 Share Posted January 24, 2009 My friends Series III diesel has lost all gears as he was driving along. I got a knock on the door yesterday "the landy's broke down, can I have a tow" for once it wasn't me He was just driving into the village when he said that there was a bang & then loss of all gears, when I went to give him a tow I tried it but nothing. There is a noise when you put it in gear & let out the clutch but hard to say what sort of noise as they are not exactly the quietest vehicles when running. I did manage to stall it in 4th gear somehow but tried it since & nothing, can't get any gears at all. I've been underneath & had a quick look but nothing obvious like a broken prop, I was thinking maybe the clutch has gone. What are the common failings on these vehicles? Quote Link to comment Share on other sites More sharing options...
minivin Posted January 24, 2009 Share Posted January 24, 2009 i) Take the PTO cover off and check the output gear is ok on the mainshaft splines. ii) While the PTO cover is off, worth pulling the gear out and seeing if the mainshaft can be moved, if so, the mainshaft bearings may have let go. iii) ummmm...... drop the oils in the gearbox and transferbox and see if anything comes out! Just remembered the dog gear on the output shaft of the transfer box, the gear that goes back and forth to engage high or low ratio, has a very crude teeth arrangement that can wear with time and result in total failure. Engage low ratio and see if the vehicle moves. Clutch-wise, if you can engage gears, I'd go away from clutch failure at this moment. Quote Link to comment Share on other sites More sharing options...
reggie Posted January 24, 2009 Author Share Posted January 24, 2009 Forgot to mention that it has had a recon box fitted not that long ago, well it hasn't done many miles since anyway. I tried engaging low & nothing. Quote Link to comment Share on other sites More sharing options...
minivin Posted January 24, 2009 Share Posted January 24, 2009 That sounds like the dog gear out the equation. Worth pulling the PTO cover for the cost of two gaskets to make sure the output gear aint come loose Quote Link to comment Share on other sites More sharing options...
rtbarton Posted January 24, 2009 Share Posted January 24, 2009 Before taking anything to bits....... Check Hi-Lo & overdrive (if fitted) aren't in neutral. If not, engage top gear, choc wheels, apply footbrake, disengage handbrake, start engine. If the propshaft is turning you have an axle problem, if not then it's gearbox or transfer box. If the axle isn't turning declutch & engage 4wd. If it tries to move (or front axle turns with FWH disengaged) the gearbox is OK and transfer box (or more accurately 4WD unit) is stuffed. Quote Link to comment Share on other sites More sharing options...
Daan Posted January 24, 2009 Share Posted January 24, 2009 If you get 4 th gear but not any other, you have broken the layshaft in the gearbox, unfortunately. Daan Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted January 24, 2009 Share Posted January 24, 2009 Has it got an overdrive? if so and its not a diff or half shaft issue i would bet on failed coupling splines on the overdrive input. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 24, 2009 Share Posted January 24, 2009 Has it popped a rear half-shaft? Had one go driving gently on the road must've been fatiguing for ages as it made no noise but the truck just didn't move pulling out of a junction Quote Link to comment Share on other sites More sharing options...
reggie Posted January 25, 2009 Author Share Posted January 25, 2009 If you get 4 th gear but not any other, you have broken the layshaft in the gearbox, unfortunately.Daan I wouldn't say that I get 4st gear, it was only when I was trying all the gears & letting out the clutch that it stalled in 4th, funny thing was I didn't feel anything like clutch bite. Normally when you stall an engine in gear you can feel it happen but this just stalled/cut out. Quote Link to comment Share on other sites More sharing options...
reggie Posted January 25, 2009 Author Share Posted January 25, 2009 Has it got an overdrive? if so and its not a diff or half shaft issue i would bet on failed coupling splines on the overdrive input. No overdrive, it hasn't been working for some time apparently. Quote Link to comment Share on other sites More sharing options...
rtbarton Posted January 25, 2009 Share Posted January 25, 2009 No overdrive, it hasn't been working for some time apparently. By that do you mean one is fitted but not working? If so did you check to see if has been knocked into neutral? This is a very common "fault." Quote Link to comment Share on other sites More sharing options...
reggie Posted January 25, 2009 Author Share Posted January 25, 2009 By that do you mean one is fitted but not working? If so did you check to see if has been knocked into neutral? This is a very common "fault." I think so, let me go & ask him after I've had some lunch. He did say to me a while back that he got quoted a lot of cash to fit another overdrive so he didn't bother. Quote Link to comment Share on other sites More sharing options...
reggie Posted January 26, 2009 Author Share Posted January 26, 2009 No overdrive fitted as it was removed a while back after it packed up. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted January 26, 2009 Share Posted January 26, 2009 Does it move in low range? if it does its a rear diff or half shaft that has failed. Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted January 26, 2009 Share Posted January 26, 2009 Does it move in low range? if it does its a rear diff or half shaft that has failed. if it has freewheeling hubs engage them first Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted January 26, 2009 Share Posted January 26, 2009 V8 Camel, look three posts up Quote Link to comment Share on other sites More sharing options...
rtbarton Posted January 26, 2009 Share Posted January 26, 2009 V8 Camel, look three posts up Or even post No5 Quote Link to comment Share on other sites More sharing options...
missingsid Posted February 7, 2009 Share Posted February 7, 2009 I wouldn't say that I get 4st gear, it was only when I was trying all the gears & letting out the clutch that it stalled in 4th, funny thing was I didn't feel anything like clutch bite. Normally when you stall an engine in gear you can feel it happen but this just stalled/cut out. So it did stall in 4th then? 4th is so high that it would just slow down and cut out instead of biting and jerking to a stop. So if it did stall in 4th and nothing in any other gear, then layshaft for sure. Try lowbox 4th it should pull away fine if it is the layshaft. When I broke my mates V8 SI and my girlfriend broke my SI V8 I drove both home in 4th. As the post is now quite old I imagine that you now know what it was? Marc. Quote Link to comment Share on other sites More sharing options...
reggie Posted February 7, 2009 Author Share Posted February 7, 2009 I haven't had a proper look at it since my first post as I've been so busy, I only managed two days in two weeks to look at my Rangie which has problem too As soon as I can spend some time on it I'll let people know what I find. Quote Link to comment Share on other sites More sharing options...
RPR Posted February 7, 2009 Share Posted February 7, 2009 I vote with Jon. If it's not a "neutral" fault, then I bet the bang was a rear half shaft letting go. It once happened to me setting off from a traffic light in Kuala Lumpur. By then I was so familiar with the process that I just slapped down the yellow plunger and continued home in front wheel drive... Quote Link to comment Share on other sites More sharing options...
reggie Posted February 16, 2009 Author Share Posted February 16, 2009 Well he got fed up waiting for me to get some time to look at it & got the garage out to come & take it away. Apparently they have looked at it & said it was a rear half shaft, I just wish he had been a little more patient, I could have saved him some cash. Quote Link to comment Share on other sites More sharing options...
