Bluemoon Posted January 25, 2009 Share Posted January 25, 2009 I know some of you are using Toughbooks for sat nav, mmaps and so on embedded I have a CF-18, which has come with a 3g network modem, but no driver to run it. I've looked at the panasonic.ca site and downloaded a driver but havn't been able to install properly(can't get passed initialization). Two things I was wondering, If anybody has a clue to my problems and how to fix and how much is the tariff, just in case its out reach of my pocket. I'm sorry for asking but I've search google and can'tfind anything. Brian Quote Link to comment Share on other sites More sharing options...
bittersweet Posted January 25, 2009 Share Posted January 25, 2009 I know some of you are using Toughbooks for sat nav, mmaps and so on embedded I have a CF-18, which has come with a 3g network modem, but no driver to run it. I've looked at the panasonic.ca site and downloaded a driver but havn't been able to install properly(can't get passed initialization). Two things I was wondering, If anybody has a clue to my problems and how to fix and how much is the tariff, just in case its out reach of my pocket. I'm sorry for asking but I've search google and can'tfind anything. Brian We have an explore tough tablet, I know that is not exactly a tough book but we run it using a gps mouse and rarely use a modem at all, it is wireless and will connect to any available unsecured network which is usually enough for us. On the subject of 3g I have an iphone which is 3g with unlimited downloads and will connect to t'internet more or less anywhere (at differing speeds) this costs me £30 a month but I have been warned to make sure roaming is disconnected if I go abroad or I might need a second mortgage. Hope this helps B Quote Link to comment Share on other sites More sharing options...
Bluemoon Posted January 25, 2009 Author Share Posted January 25, 2009 Just thought it would be nice the have the internal modem working, I have a dongle, , but I can't any info on internal modem tariffs, been into various phone shops and they havn't a clue, and just try and sell a phone to me! Brian Quote Link to comment Share on other sites More sharing options...
landmannnn Posted January 26, 2009 Share Posted January 26, 2009 Check that wireless is not disabled in the BIOS, my company one sure is. Check the device manager under windows. You will need a 3g card in the modem to be able to install the drivers in my experience. Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted January 26, 2009 Share Posted January 26, 2009 You will need the driver from the makers of the 3g card and not the laptop makers. I do know that 3g cards will work with a cf18 as I had one with mine. Also if it was a non-3g sim card there is a slot on the rear for the card to go in. Paul Quote Link to comment Share on other sites More sharing options...
Bluemoon Posted January 27, 2009 Author Share Posted January 27, 2009 checked it under windows , and says it working properly, but can't talk to it, says check interupt? and it doesn't use a sim card. Any ideas? Brian Quote Link to comment Share on other sites More sharing options...
GBMUD Posted January 27, 2009 Share Posted January 27, 2009 Not sure it is possible to have a mobile connection without a SIM. Are you sure it does not have one somewhere - inder a small cover on the bottom of the machine perhaps? Is there a 'function' key to enable the card? On my laptop I have to press the blue 'function' button at the bottom left and then F9 to make the WiFi work, perhaps yours is similar? Another machine you have to press the same key multiple times to turn on WiFi or Bluetooth or both or neither... HTH Chris Quote Link to comment Share on other sites More sharing options...
Bluemoon Posted January 27, 2009 Author Share Posted January 27, 2009 yes , its got a dedicated wireless switch to the side of the machine, and yes its switched on, but still no good. Brian Quote Link to comment Share on other sites More sharing options...
landmannnn Posted January 27, 2009 Share Posted January 27, 2009 checked it under windows , and says it working properly, but can't talk to it, says check interupt? and it doesn't use a sim card. Any ideas?Brian If it doesn't use a sim card it cannot be a 3g device, are you sure it isn't just a wireless network card? Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted January 27, 2009 Share Posted January 27, 2009 According to this: CF-18 Spec sheet the CF-18 does come with a GSM/GPRS NOT 3g option. However, it also says it has a SIM slot. I suggest you try and find the slot and stick in a SIM card to see what happens... Quote Link to comment Share on other sites More sharing options...
JST Posted January 27, 2009 Share Posted January 27, 2009 sim socket is on the back edge RHS Quote Link to comment Share on other sites More sharing options...
Bluemoon Posted January 28, 2009 Author Share Posted January 28, 2009 Its a Sierra SB555 wireless module, but just found out it is no longer supprted, from the Sierra website never mind. Brian Quote Link to comment Share on other sites More sharing options...
landmannnn Posted January 28, 2009 Share Posted January 28, 2009 You should be able find the driver www.driversguide.com. You will have to register (free, of course) Quote Link to comment Share on other sites More sharing options...
Philip Tonkin Posted January 28, 2009 Share Posted January 28, 2009 I think I have the aircard watcher software for that card. Not supported does not mean not available. My company uses over 1000 toughbooks but all are fitted with SW 750 GPRS cards rather than using the internal cards. Quote Link to comment Share on other sites More sharing options...
