Tubela H3PR
bishbosh
My £23 :rolleyes: tube bender wont hold pressure :( .
Took it in to my local hydraulics place and they are telling me that it is very difficult to take apart and they would have to send it off to be repaired.
As Tubela want £100 for a seal kit, sending the machine to them doesn't exactly look too attractive financially!
So, has anyone successfully taken one apart and replaced seals?
No, mine leaks a bit and Mr Moglite gave me some Citroen hydraulic fluid (I think) which swells the seals and stops the leaks a bit.
How bad is it? Can you just keep pouring it in the top?! think of it as fuel to run the bender on! :D
At the end of the day, what is SO hard about taking it apart? I'd have a crack and just replace the seals with off the shelf equivalents at 5% of the price?
Al.
P.S. You can do mine while you're at it!
You havent broke it already Bish , Cant be that difficult to take apart , and seals are only pennies from the right places .
Drop it in if you are passing ,
That reminds me I still have yer Front cage here , We are starting a job in Highbridge this week , so I may be down your way to drop it off .
but dont ask him if you want it back together this side of 3050 ;)
Bish if you do take it apart can you get some pics as i have one two, as an aside mine is missing the in/out lever knob and wondered if you have a pic of the correct one.
Cheers, Will.
Yup the threaded shaft is there its just missing the ball.
As the end of the shaft is sharp and the lever often requires some effort to move it starts to mash your hands up after a while (not that thats really spurred me into doing anything about it :rolleyes: )
A pic would be handy, and if its what i think it is i might be able to nick one off a jcb control lever.
Mr BishBosh
Please will you as a longer term member
remember and use in the future the LR4x4 Forums 'special features'
Mr W is "expert" at taking things apart............. :)
Nige
Critically Bish wants to put it back together again which may be a problem :P . That said, how tricky can it be and, if you fail, you can send it tubela any they can lighten your wallet by £100
I have much the same problem with mine, not sure whats the best fluid to use in it ethier, sadly mine wasn't £23quid and is missing the former which will do roll cage tube :(
Anyway, I pestered tubela enough to give me the diagrams and parts list. prices are probably out of date but might be of use.
not sure how well this will display, but the forums won't let me upload .doc files
SPARE PARTS PRICE LIST – MODEL H3PR PUMP – 1ST MAY 2007
RAM & CYLINDER PARTS for 2/3/4/5M
Item No. No. Required Description Price each £
1 1 Cylinder Assembly only 195.00
8 1 Handle Assembly 65.50
13 1 Roller 8.20
16 1 Pivot 9.30
17 1 Outer Plunger 45.50
19 &20 1 Inner Plunger & Collar (Assembly) 57.50
21 1 Plunger Body 57.00
23 1 Valve Block Connecting Bolt 56.00
24 1 *1/4" (6 x 10 x 1mm) Valve Retaining Screw 0.80
25 --------- Discontinued ---------
34 1 Forward Connecting Tube 18.50
35 1 Forward Connecting Bolt 54.00
37 1 Reservoir Cover 127.00
41 1 Oil Filler Cap 24.00
42 & 53 1 Oil Filter Cap & Filter 39.00
43 1 Oil Filter Paper Gasket 1.60
44 1 Front Gland Ring 53.00
45 1 Front Bush 54.00
46 1 Ram 130.00
49 1 Cover Gasket 5.50
54 1 Plunger Spring 7.50
55 --------- Discontinued ---------
60 1 Roller Pin 6.80
61 1 Handle-Plastic Grip 3.80
62 1 2 1/8" O.D x 1 3/4" I.D. 'O' Seal 3.40
63 1 1 1/8" O.D x 7/8" I.D. 'O' Seal 1.50
64 3 7/8" O.D x 1 1/16" I.D. 'O' Seal 1.50
66 1 2" BSP Bonded Seal 6.20
67 3 3/8" BSP Bonded Seal 1.50
69 --------- Discontinued ---------
70 2 1/4" BSW Bonded Seal 1.50
71 1 5/8"dia. Cup Washer 7.95
72 3 *3/8" BSF x 1" (10 x 25 x 1.25mm) Long Socket Head Cap Screw 0.80
73 6 * 5/16" x 1 1/4" BSW (8 x 30 x 1.25mm) Long Socket Head Cap Screw 0.80
76 2 *1/4" BSF x 1/2"(6x15x1mm) Long Hex. Set Screw 0.80
77 --------- Discontinued ---------
* Metric Threads are now being used - Check thread before ordering
ENGINEERING CO. LTD
79 1 7/8" BSF (22 x 2.5mm) Full Nut 3.90
81 1 3/16"dia x 1 1/4" Long Grooved Pin 0.80
82 2 5/8"dia 'E' Clips 1.50
83 1 Leather Washer 3.20
85 2 1/4"dia Ball 0.80
86 2 1/4" O.D. Tubing Nut 4.70
87 2 1/4" O.D. Tubing Sleeve 4.70
88 1 Cylinder Rear Cap 66.50
91 1 Front Cylinder Packing 21.00
92 1 3/4" Hardened Cap 11.00
93 & 109 1 Control Valve Block (see below) ---------
94,78 & 96 1 Control Valve Extension (Assembly) 38.50
95 1 Control Valve Cap (side plate casting) 38.75
97 1 Rear Cylinder Gasket 6.50
98 1 Front Cylinder Gasket 6.50
99 1 Rear Packing Ring 21.50
100 1 Rear Ram Collar 42.00
101 1 Front Packing Ring (2 Part assembly) 42.50
102 2 2 1/4" Cup Washers 7.60
103 1 Control Valve Cap Gasket 3.90
104 1 1" O.D. x 3/4" I.D. 'O' Seal 1.50
106 1 3/8" BSP Nut (12mm x 1mm from MID 1998) 9.00
107 1 5/8"dia Washer 0.80
108 4 *1/4" BSW x 7/8" (6 x 25 x 1mm) Socket Head Cap Screw 0.80
109 1 Control Valve supplied complete with item No's 93,94,96,106,107,111 237.00
110 1 Reservoir 168.00
111 1 Control Valve Arm Knob 2.95
112 1 Ram/Cylinder Assembly complete 510.00
ORDER Ram / Cylinder Spares fro H3M / 4H / 4M / 5H / SM
REF:
State Model 1 Cylinder 310.00
20" Stoke 1 Ram 205.00
State Model 1 Ram/Cylinder Unit complete Assemble 670.00
Rear Ram Packing Assembly use items No’s – 63-99-100-101 & 102
Service Kits available as follows: -
Model H3PR, H3PRSF 75.00
Spare Parts Kits for H2M - H3M - 4M & 5H per Ram/Cylinder 45.00
Ha ha!
I was just about to post the same info! I spoke to and then emailed Tubela yesterday and got the same info back by email today. I have a 2008 pricelist and prices are about 5% higher on my sheet.
Maybe we should have a "self help" group where we all take our H3PR's and try and fix them together!! :D
What size former are you looking for.... could possibly lend you one if I have it....?
Cheers al just what i thought, At about £3.50 for a new one i might have to splash out and buy a genuine one :lol:
We could nearly start a club with the amount of these on here, mine has a big blue metal box with the tubela logo on it with all the formers in, is this a genuine thing? anyone else got one?
Will.
Will.
maybe we should ask for our own forum :)
yeah that's how the kit comes from the factory, mine is sans box as are most that come up for sale. One thing to bear in mind, tubela only ever took cheques and postage was pretty unreasonable last time I spoke to them (admittedly that was a while back, hopefully things are a bit better), but you 3.50 part may cost 25quid :(
If you strip yours can you post up a few pics as I'll be attacking mine soon too.
  • 3 weeks later...
