oil cooler pipes and heater pipes on disco 200tdi engine
Don't know about the oil cooler pipes, I just replaced them as they were. The heater should be connected with the hose from the cylinder head to the front connection and the rear connection to the pipe along the head.
And I can't see that there would be any significant difference if you do it vice versa... :unsure:
