was a nice truck? Posted February 14, 2006 Share Posted February 14, 2006 Help ive just checked the level in my borg warner transfer case and the oil that has come out is a bit scarry!! Should it be ep90 or atf??? If it should be atf then the last lot is in real bad nick having only done 8000 miles or so. If anyone knows what should be in there i would be right grateful. Thanks in advance Dave Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted February 14, 2006 Share Posted February 14, 2006 Help ive just checked the level in my borg warner transfer case and the oil that has come out is a bit scarry!!Should it be ep90 or atf??? If it should be atf then the last lot is in real bad nick having only done 8000 miles or so. If anyone knows what should be in there i would be right grateful. Thanks in advance Dave Hi Dave, Certainly ATF NOT ep90 Quote Link to comment Share on other sites More sharing options...
was a nice truck? Posted February 15, 2006 Author Share Posted February 15, 2006 Thanks, the haynes comic was erring on ep90 but i dont think that was for a bw transfer case. It would be nice to know why the last lot got so burnt though, ideas anyone. The level was spot on just absolutly knackered oil Dave Quote Link to comment Share on other sites More sharing options...
jules Posted February 15, 2006 Share Posted February 15, 2006 Check to cooler is ok and move it so it get more airflow Quote Link to comment Share on other sites More sharing options...
MogLite Posted February 15, 2006 Share Posted February 15, 2006 Check to cooler is ok and move it so it get more airflow On a transfer box - oh thats hardcore Quote Link to comment Share on other sites More sharing options...
jules Posted February 15, 2006 Share Posted February 15, 2006 On a transfer box - oh thats hardcore good point My transfue box was the same when we serviced it last month and I was looking at fitting cooler some how Quote Link to comment Share on other sites More sharing options...
was a nice truck? Posted February 15, 2006 Author Share Posted February 15, 2006 cooler is a brilliant idea, If you manage to fit one please post I would certainly be interested. Cheers dave Quote Link to comment Share on other sites More sharing options...
jules Posted February 15, 2006 Share Posted February 15, 2006 There must be away if you place the intake and out let at the same level with the intake very close to a large submerged gear and the outlet in a relitivly open area the gear would force the fluid to move through the system but it could only be close to the transfure box and bleading would be a pain. fitting a electric pump with a thermostatic controll and fan is the easy option Quote Link to comment Share on other sites More sharing options...
MogLite Posted February 15, 2006 Share Posted February 15, 2006 cooler is a brilliant idea, If you manage to fit one please post I would certainly be interested. Cheers dave That would be pretty tricky IMHO. There is no oil-pump as such, so you'd be getting into the same technology that NASCARs etc use to add oil coolers to the rear diff. You aren't running sump guards by any chance are you ? Quote Link to comment Share on other sites More sharing options...
jules Posted February 15, 2006 Share Posted February 15, 2006 That would be pretty tricky IMHO. There is no oil-pump as such, so you'd be getting into the same technology that NASCARs etc use to add oil coolers to the rear diff.You aren't running sump guards by any chance are you ? The box does not need to cooling that the auto box needs so as long as a gear is moving there is a flow generated there for the hydrolic movment should alow it to flow around a system that is not to complex and syfon would do the rest. (sorry I could be talking total rubbish as I sat my hydrolics paper about 11yrs ago) Quote Link to comment Share on other sites More sharing options...
was a nice truck? Posted February 15, 2006 Author Share Posted February 15, 2006 I cant help but feel there is a cause of the heat and curing that may be easier than sorting a coller. Not as 'ardcore' mind Dave Quote Link to comment Share on other sites More sharing options...
GBMUD Posted February 15, 2006 Share Posted February 15, 2006 I cant help but feel there is a cause of the heat and curing that may be easier than sorting a coller. Not as 'ardcore' mindDave This is a Range Rover with a viscous coupling is it? Are the front and rear tyres the same size? I am guessing that running different sizes front and rear may cause some heat buildup. The viscous unit is OK I suppose? Chris Quote Link to comment Share on other sites More sharing options...
