muddy Posted February 6, 2009 Share Posted February 6, 2009 Evening all, mateys recently acquired td5 auto has developed a loud screech when under hard acceleration, sounds almost like the aux belt slipping or possibly waterpump bearings as the fan cuts in putting extra load on them? It happens intermittently and only when you are a WOT or very near it. I got him a new auxiliary belt to see if that caused it but upon initial inspection i cant see how you remove/refit, do they have an automatic tensioner like the 300's? All this plastic really gets in the way Finally he wants some new tyres and i suggested the general AT2's, he has the 16" alloys like these: Whats the max size you can fit without mods and maybe the max size with sensible mods? Cheers, Will. Quote Link to comment Share on other sites More sharing options...
Cliffh Posted February 6, 2009 Share Posted February 6, 2009 Evening all, mateys recently acquired td5 auto has developed a loud screech when under hard acceleration, sounds almost like the aux belt slipping or possibly waterpump bearings as the fan cuts in putting extra load on them? It happens intermittently and only when you are a WOT or very near it.I got him a new auxiliary belt to see if that caused it but upon initial inspection i cant see how you remove/refit, do they have an automatic tensioner like the 300's? All this plastic really gets in the way Finally he wants some new tyres and i suggested the general AT2's, he has the 16" alloys like these: Whats the max size you can fit without mods and maybe the max size with sensible mods? Cheers, Will. Have a look at the exhaust manifold studs, they have been known to fail and cause screeching noises Quote Link to comment Share on other sites More sharing options...
muddy Posted February 8, 2009 Author Share Posted February 8, 2009 Well further (breif) investugation has found this which i'm guessing shouldnt be like that? definate evidence of soot deposits around it aswell. Close ups are looking down between the hose and engine lifting bracket just on from where the EGR pipe exits. I guess that there should be a stud in there? Will. Quote Link to comment Share on other sites More sharing options...
elmscroft Posted February 8, 2009 Share Posted February 8, 2009 Hi, Had the same problem last year. You will probably find studs loose or sheared on number one exhaust manifold port. Can be seen with sound cover off. Although fiddly it was a DIY fix, with some help in getting manifold skimmed. Mike Quote Link to comment Share on other sites More sharing options...
