The Badger Posted February 6, 2009 Share Posted February 6, 2009 So I have a TD5 bulkhead, will this fit with a 300 tdi engine and R380 gearbox. Also, the front cross member on a 300tdi, is this a tubular version, or a box version with mounts on it? (As I have been sent a lovely galvanised box version from richards chassis as they only just remembered) And the most stupid question, which way round does it bolt in??? (if it is the box version that is, as I have a tubular one that I took off the donar verhicle) And the last question, I have twin shocks going onto the rear, so there has been holes drilled either side of the rear spring mount into the chassis to take the shock brackets either side. However, they have welded into the chassis an extra rear crossmember just behind the rear spring mount, but this has been placed over the rear of two of the inside holes that take the extra rear shock mount. So have richards messed up by putting the crossmember in the way, or putting the holes in the wrong place??? As it is pretty stupid and I can re-drill to fix, but I just need to check. all these questions, one day I will have all the answers, right? Quote Link to comment Share on other sites More sharing options...
Shox Dr Posted February 7, 2009 Share Posted February 7, 2009 I'd say it doesn't mater what type of cross member you have so long as it fits. As for the correct way, the plates face backwards. As for he spring mount holes, Mmmmmmm me thinks they might have... unless they have a captive nut. Quote Link to comment Share on other sites More sharing options...
The Badger Posted February 7, 2009 Author Share Posted February 7, 2009 yep, me thinks that have too.... checked eastcoast rover out, they have a images of the correct tdi member (which is the one I have from richards, great) here is the link to that one - http://www.eastcoastrover.com/Discotech2.html Quote Link to comment Share on other sites More sharing options...
jacks906 Posted February 7, 2009 Share Posted February 7, 2009 hope pic helps with correct fitment dave Quote Link to comment Share on other sites More sharing options...
The Badger Posted February 7, 2009 Author Share Posted February 7, 2009 Thanks for the pic, got it in there now, bolted up ok with a little bit of fine adjustment. spoke to richards, yep, it's the wrong hole pattern all right.... time to get the drill out! Quote Link to comment Share on other sites More sharing options...
