Smokydiesel Posted February 6, 2009 Share Posted February 6, 2009 Hi, I'm converting my 2,5 NA to a Disco 200 TDI and parts-wise I'm almost there. Now I know that the high pressure PAS hose from the pump to the box is a problem (connection on pump is different) I was thinking, would a new Pump to Box hose from a Defender or Discovery 200 TDI do the job ?? 2 items I can think of: Is the hose long enhough ? Will the box-end of the pipe fit my 2,5 na steering box ? (or is the NA steering box different from the one used in 200 TDI s..) Thanks ! Edwin. Quote Link to comment Share on other sites More sharing options...
western Posted February 6, 2009 Share Posted February 6, 2009 if your old engine had power steering pump fitted, you could use that pump & hoses on the 200Tdi. steering box threads depend on which box is fitted 3, 4 or 6 bolt holding the top cover on ? Quote Link to comment Share on other sites More sharing options...
Smokydiesel Posted February 6, 2009 Author Share Posted February 6, 2009 if your old engine had power steering pump fitted, you could use that pump & hoses on the 200Tdi.steering box threads depend on which box is fitted 3, 4 or 6 bolt holding the top cover on ? Hi, My old engine has a PAS pump but I thought that swapping pumps would mean welding up a new bracket (that's what I'm not good at..) Mmmmm... might have to do a new search on the forum here.... Will have a look at what box I have tomorrow. Thanks ! Edwin Quote Link to comment Share on other sites More sharing options...
western Posted February 6, 2009 Share Posted February 6, 2009 the alternator/pas pump bracket on the old engine is either ERC6974 or ETC8854, on a Defender 200Tdi it's ETC8854, The Discovery one is different again but the old engines bracket should fit, got to be with a go at swapping them over. Quote Link to comment Share on other sites More sharing options...
Eightpot Posted February 6, 2009 Share Posted February 6, 2009 I went through a bin of pipes at a land rover breakers and found one of a range rover with the correct fitting on it for the steering box end. Quote Link to comment Share on other sites More sharing options...
666 george Posted February 7, 2009 Share Posted February 7, 2009 I had mine changed over at pirtek, had a different size thread Quote Link to comment Share on other sites More sharing options...
