The Homba Posted February 7, 2009 Share Posted February 7, 2009 Hi , i have a 200tdi engined 110 that has just started smoking bad when you give it some throttle , coolant is ok no drop in level and the oil is low but not any more that normal thought it might be the turbo as there is some oil on the turbo but still have pressure and there no drop in power . any ideas of what it could be down to ? Thanks in advance Iain Quote Link to comment Share on other sites More sharing options...
western Posted February 7, 2009 Share Posted February 7, 2009 is the air filter clean ? if not try a new one. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 7, 2009 Share Posted February 7, 2009 Smell the smoke - if it smells of diesel, then it's a fuel/possible timing problem. Les. Quote Link to comment Share on other sites More sharing options...
Cat_J Posted February 8, 2009 Share Posted February 8, 2009 Don't buy morrisons diesel. Round here it killed my friends 2008 mondeo (ford say the fuel trashed the injectors), my boss' van (AA had to recover and the fuel system had to be drained and flushed), and my 200tdi would barely run and smoked. All last week. I went to a different garage and filled up and after a couple of days of driving its back to its normal, more powerful, self. Just a thought that there seems to be some really shi**y fuel out there at the moment. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted February 8, 2009 Share Posted February 8, 2009 Smell the smoke - if it smells of diesel, then it's a fuel/possible timing problem.Les. And if the smoke smell makes you feel nauseus it is oil being burnt. Normally grey rather than white. Quote Link to comment Share on other sites More sharing options...
The Homba Posted February 8, 2009 Author Share Posted February 8, 2009 Thanks for the replys guys , the air filter is a foam k&n type wich i keep meaning to change to the proper one , as for the colour i couldnt realy tell as it was getting dark ( it was the police that told me they were behind when it happend ) fuel wise most always use shell as its next to my house .had the timing belt done just before xmas do you think it could have sliped ? thanks Iain Quote Link to comment Share on other sites More sharing options...
western Posted February 8, 2009 Share Posted February 8, 2009 might be worth rechecking the injection pump timing. Quote Link to comment Share on other sites More sharing options...
Cat_J Posted February 8, 2009 Share Posted February 8, 2009 Thanks for the replys guys , the air filter is a foam k&n type wich i keep meaning to change to the proper one , as for the colour i couldnt realy tell as it was getting dark ( it was the police that told me they were behind when it happend ) fuel wise most always use shell as its next to my house .had the timing belt done just before xmas do you think it could have sliped ? thanks Iain Isn't the belt supposed to be retightened after 500 miles or so anyway? Quote Link to comment Share on other sites More sharing options...
western Posted February 8, 2009 Share Posted February 8, 2009 Isn't the belt supposed to be retightened after 500 miles or so anyway? Nope, I never redone mine after 500miles. no mention of a retighten in the genuine Defendr workshop manual about it. Quote Link to comment Share on other sites More sharing options...
Cat_J Posted February 10, 2009 Share Posted February 10, 2009 That saves some hassle then. Is it worth checking the timing after a while though, can the belt stretch? Quote Link to comment Share on other sites More sharing options...
The Homba Posted February 11, 2009 Author Share Posted February 11, 2009 still havent been able to check it yet asked a friend to smell it when i give it a rev and he say it smelt like diesel ( but he not to good with things like that ) hoping to get it in the garage at work this week . just a thought but the engine is a bit noisier think the rockers need adjusted could this cause the smoke / Thanks Iain Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 11, 2009 Share Posted February 11, 2009 If the tappet gaps have closed up, then that would make the engine rattly/smoky. Les. Quote Link to comment Share on other sites More sharing options...
The Homba Posted February 11, 2009 Author Share Posted February 11, 2009 If the tappet gaps have closed up, then that would make the engine rattly/smoky.Les. Thanks les just hope thats all thats wrong with it . Iain Quote Link to comment Share on other sites More sharing options...
western Posted February 11, 2009 Share Posted February 11, 2009 That saves some hassle then. Is it worth checking the timing after a while though, can the belt stretch? not noticed any stretch in my engines timing belt, more likely to snap than stretch. Quote Link to comment Share on other sites More sharing options...
zulublue Posted February 11, 2009 Share Posted February 11, 2009 Burnt valve, sounds similar to mine a couple of weeks ago Quote Link to comment Share on other sites More sharing options...
yellow90 Posted February 11, 2009 Share Posted February 11, 2009 a cam belt doesn't stretch, if u say it sounds noisy, is it a harsh diesel knock your hearing? indicating the timing being too advanced and smoking?? Quote Link to comment Share on other sites More sharing options...
zulublue Posted February 11, 2009 Share Posted February 11, 2009 I was getting the grey/white smoke and had a knocking noise which I could hear more from the exhaust end, I took the head off and had it checked one of the exhaust valves had chipped off but from underneath so not noticable from the top. All sorted now. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 12, 2009 Share Posted February 12, 2009 Timing belts do stretch a small amount during their service life, which is why an old belt is always slack when you come to remove it. Once fitted correctly - there's no further need to check and adjust it. Les. Quote Link to comment Share on other sites More sharing options...
The Homba Posted February 15, 2009 Author Share Posted February 15, 2009 Hi guys spent the weekend checking timming (ok), tappets (ok) changed the fuel filter (very dirty with small red bits in it) changed the air filter back to a proper one took it for a spin and all seemed great only a small amount of smoke so decided to take the dog up the hills and then it was back to the same lots of smoke and i can heer the turbo whine had a look and there is oil in the intercooler and all down the down pipe looks like the turbo has gone so the question is now wheres the best place to get a turbo ? Cheers Iain Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 15, 2009 Share Posted February 15, 2009 You can get your own turbo reconditioned, or an exchange unit, which is a lot cheaper than a new one. Shop around though, the prices vary enormously. Les. Quote Link to comment Share on other sites More sharing options...
