maxtherotti Posted February 10, 2009 Share Posted February 10, 2009 hi all i picked up my disco on sat all ok drove 180 miles on sunday then yesterday started having big probs getting into gears now the full clutch was repleced last march (done 17k since) but the garage is saying the original warranty is with the purchaser not the car so its no longer valid?? is this correct? sounds wrong to me rob Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 10, 2009 Share Posted February 10, 2009 Some sellers don't guarantee some components, such as brake linings, clutches, etc. The clutch should have lasted a lot longer than that though. Have you read the fine print on the back of the reciept/invoice? As you are the 3rd party, I would expect you'll have to pay to get it fixed yourself - any guarantee might be with the previous owner and not where he/she bought it from. Les. Quote Link to comment Share on other sites More sharing options...
maxtherotti Posted February 10, 2009 Author Share Posted February 10, 2009 bugger rob any one know of a good local garage to daventry that can fit a ckutch job in this week?? Quote Link to comment Share on other sites More sharing options...
disco_al Posted February 10, 2009 Share Posted February 10, 2009 unless it's a guarenteed for life unit, with transferable warranty, then you are stuffed i am afraid. IIRC the only clutch manufacturer to offer a transferable warranty is Quinton Hazell. Most manufacturers stipulate that the warranty cannot be passed on - looks like you have a bill for a clutch coming up? is the clutch fluid up to level, any leaks from the cylinders? clutch fork replaced at the same time? could be other things, other than the clutch of course..... Quote Link to comment Share on other sites More sharing options...
maxtherotti Posted February 10, 2009 Author Share Posted February 10, 2009 it,s a borg and beck clutch they fitted they also replaced the fork/release brg/spigot bush/release brg guide/prop rubber etc etc clutch fluid level is spot on when pedal is pressed there is a lot of squeaking in side the bell housing so im guessing the fork or cover plate is at fault double bugger rob Quote Link to comment Share on other sites More sharing options...
