Muther Trucker Posted February 10, 2009 Share Posted February 10, 2009 does anyone know if a bulkhead off a 2008 puma defender will fit on a 1989 110 with a retro fit disco 200tdi??? i`m guessing there will be some holes need making/blanking, but is the overall size + shape of the "A" posts etc the same??? Quote Link to comment Share on other sites More sharing options...
western Posted February 10, 2009 Share Posted February 10, 2009 you'd be better off obtaing a Td5 bulkhead & modding it like this http://forums.lr4x4.com/index.php?showtopic=38064 Quote Link to comment Share on other sites More sharing options...
JST Posted February 10, 2009 Share Posted February 10, 2009 the floor plan is different as are all the mountings for the dash you would need to graft the old floor plan folds onto the PUMA bulkhead plus all the dash mounting points. Even if i had a puma bulkhead in my garage i would still just fit a td5 bulkhead. unless of course the one you have is complete and you just need to change the floor plan and work out the wiring which wouldnt be that hard. Quote Link to comment Share on other sites More sharing options...
The Badger Posted February 11, 2009 Share Posted February 11, 2009 Just double checking. Is the link to the that bulkhead swap to convert a TD5 bulkhead to 300tdi bulkhead? If so im on it, as i managed to pick up a perfect TD5 for £50 cheers Quote Link to comment Share on other sites More sharing options...
