cooper Posted February 10, 2009 Share Posted February 10, 2009 Hi my Rangie broke down last sunday,I was driving along and the engine just died on me, it wouldn't start, occasionally it would try and start but then nothing other times. Just had a look it, turned it over first time and she started ran for 10 mins then stopped, where abouts is the relay located and what colour is it? Or does anyone else know what could cause this Cheers Shaun Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 10, 2009 Share Posted February 10, 2009 Petrol? Diesel? Year? Relay for what? All the above would help a lot Quote Link to comment Share on other sites More sharing options...
cooper Posted February 10, 2009 Author Share Posted February 10, 2009 its a 92' 3.9 V8 and its the relay for the fuel pump sorry not quite with it at present Quote Link to comment Share on other sites More sharing options...
cooper Posted February 11, 2009 Author Share Posted February 11, 2009 Dose no one know ????? Really need some help please fella's!!! Got a pay and play day in less than a month so need her up and running Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 11, 2009 Share Posted February 11, 2009 Relay is with the ECU under the seat, be aware it is ECU controlled so until the ECU sees pulses coming from the coil -ve terminal it will not switch the fuel pump on. From memory it switches the ground side of the relay to make it come on. Full fault finding guide & wiring diagrams in the technical archive. Quote Link to comment Share on other sites More sharing options...
Zorba Posted February 11, 2009 Share Posted February 11, 2009 Here's a copy of the EFi diagram out of Rave. HTH's Zorba Quote Link to comment Share on other sites More sharing options...
