graemejudge Posted February 10, 2009 Share Posted February 10, 2009 do you need any special tools to undo the torx bolts or can you get a regular spanner or socket on them Quote Link to comment Share on other sites More sharing options...
western Posted February 10, 2009 Share Posted February 10, 2009 You need the correct Torx driver that fits inside the bolt head, Halfords is probably your nearest place to get the right size. http://www.torp-fasteners.no/style/documents/torx.pdf Quote Link to comment Share on other sites More sharing options...
graemejudge Posted February 10, 2009 Author Share Posted February 10, 2009 thank you will give them a try Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 10, 2009 Share Posted February 10, 2009 Normal ring spanners will fit on torx head bolts, such as 8mm ring on a T15, and so on. Torx sockets can also be undone with allen key (hex head) tools, but you need to test fit them to get a good bite/fit. Les. Quote Link to comment Share on other sites More sharing options...
graemejudge Posted February 10, 2009 Author Share Posted February 10, 2009 will give them a go any one happen to know what size the torx bolts are on shafts at this moment cheers Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 11, 2009 Share Posted February 11, 2009 Prop flange bolts? E12 Torx and 17mm nuts. Les. Quote Link to comment Share on other sites More sharing options...
