slm Posted February 11, 2009 Share Posted February 11, 2009 any ideas please before i start wasteing money. up to 2000rpm the engine is fine my problem is over that in all gears. power is there but its as though its getting blocked. you can set revs to 2500rpm but it will then flactuate between 2500rpm and 2250 rpm up and down constantly. air filter is dry and clean. fuel level is always over 1/4 tank. have added a further 20 litres and added some injecter cleaner no change. had new injecters last year and new head. has 150k on clock. has also a zeus timing gear conversion which has always been noisy and rattley. i did go through some flood water water the other day 3 1/2 ft but no problems. went up a steep hill afterwards so high revs but no problems. it was the morning after. any ideas would be great thanks for your time. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted February 11, 2009 Share Posted February 11, 2009 Is it manual transmission or automatic? Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted February 11, 2009 Share Posted February 11, 2009 while it is misfiring , is it smoking white smoke a lot? if so it could be a fuel blockage (filter etc) Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted February 11, 2009 Share Posted February 11, 2009 The first four things that spring to mind: 1. Sedimenter (just take it off and clean it) 2. Fuel filter 3. Lift pump 4. Air leak (Get a clear plastic cheapo filter, doesn't matter what kind and connect it in the diesel return line...look for bubbles while engine running) Quote Link to comment Share on other sites More sharing options...
slm Posted February 11, 2009 Author Share Posted February 11, 2009 Is it manual transmission or automatic? Quote Link to comment Share on other sites More sharing options...
slm Posted February 12, 2009 Author Share Posted February 12, 2009 Is it manual transmission or automatic? manual Quote Link to comment Share on other sites More sharing options...
slm Posted February 12, 2009 Author Share Posted February 12, 2009 while it is misfiring , is it smoking white smoke a lot? if so it could be a fuel blockage (filter etc) no white smoke power is still there just being restricted Quote Link to comment Share on other sites More sharing options...
slm Posted February 12, 2009 Author Share Posted February 12, 2009 The first four things that spring to mind:1. Sedimenter (just take it off and clean it) 2. Fuel filter 3. Lift pump 4. Air leak (Get a clear plastic cheapo filter, doesn't matter what kind and connect it in the diesel return line...look for bubbles while engine running) will have a look at these at the weekend and see what happens thanks for your time Quote Link to comment Share on other sites More sharing options...
