turbo boost
ben
i everyone
Td5 51 plate 67000 on the clock and the turbo boost as dropped off. Not really getting any boost unless i give the old girl everything she's got in every gear and you only feel a bit of boost.
Has the turbo come to the end of its life or is there more of a problem.
Any help would be great before my wallet has to tell me the problem.
Thanks ben
On the Td5 defender the nearside boost hose has a habbit of rubbing on a wing bolt when expanded on boost , This wears them a bit thin and leaky .The turbos generaly dont give much problem if regularly serviced with good quality oil .
Have seen that a few times lately....
Other things that could be causing problems:
Failed Pipework (as above) - I have even seen a pipe which had delaminated internally so you had a flap hanging down.
Failed MAP sensor (one on the intake manifold) - or it's full of crud from the EGR set-up.
Cracked or partially siezed wastegate - allowing exhaust gas to bypass the impeller rather than making it spin.
Split intercooler!! (again, have seen this quite a few times - both standard and some aftermarket ones suffer)
Failed EGR Valve
Blocked Air Filter
Ian
