Allisport Hoses
Cat_J
 Share
Got some allisport hoses for the turbo and one of them is too small to fit any of the pipes. So far I just did the bottom pipe and the straight and left the other out but has anyone else had this. Is it supposed to be smaller and I'm just being to gentle or are they all the same diameter.
Cheers.
Oh, And I get a bit of a woosh noise at high acceleration now but nothing when out of gear on the drive. Seems to be performing a bit better though so I ignored it. I checked the hose from the filter to the turbo but all seems to be well there.
As a side note does anyone know a good replacement for the hose mentioned about, its getting old.
Cheers.
My set from them were really tight onto the L shaped pipe at the end near the inlet manifold. It went on in the end but it was tricky. They should all be the same size.
 Share
