max-ie Posted February 14, 2009 Share Posted February 14, 2009 Have a look, sheer inovation!!!!! http://cgi.ebay.co.uk/Range-Rover-V8-Water...A1%7C240%3A1318 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 14, 2009 Share Posted February 14, 2009 So you use that to keep the dirt off the dizzy after fitting EDIS, yes? Quote Link to comment Share on other sites More sharing options...
max-ie Posted February 14, 2009 Author Share Posted February 14, 2009 God knows what it is, i've never seen anything like it. It looks like a cut down glove, i bet someone buys it though!! Quote Link to comment Share on other sites More sharing options...
Dave W Posted February 14, 2009 Share Posted February 14, 2009 There's a few places that have sold them in the past, not tried them myself as I went Megasquirt but they might help if you didn't do anything else to the ignition system. Good luck with finding a 9 fingered glove Quote Link to comment Share on other sites More sharing options...
treebloke Posted February 15, 2009 Share Posted February 15, 2009 The guy that makes them lives in Shrewsbury. I have had one on my old 1985 3.5 for two years. I once had the engine completely under water although not by choice for approx ten minutes, it ran fine. So they work . Quote Link to comment Share on other sites More sharing options...
landmannnn Posted February 15, 2009 Share Posted February 15, 2009 The guy that makes them lives in Shrewsbury. I have had one on my old 1985 3.5 for two years. I once had the engine completely under water although not by choice for approx ten minutes, it ran fine.So they work . Although the rubber perishes after a couple of years. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted February 15, 2009 Share Posted February 15, 2009 Although the rubber perishes after a couple of years. £1.70 every couple of years works out a lot cheaper than the WD-40 that would be used trying to coax life out of it otherwise... A good deal less work than Mega[jolt|squirt] and EDIS too (though by no means as good or permanent a solution). Quote Link to comment Share on other sites More sharing options...
teslo Posted February 16, 2009 Share Posted February 16, 2009 and what about vent hole at the bottom of dizzy? My experience is that if you have your ingition system in good order you dont't need that kind of thing. As was somewhere here stated before...use genuine parts, tak care of system, use some silicone sealant and grease and you will be fine. If you want something more go for EDIS, MS... Quote Link to comment Share on other sites More sharing options...
