TheBeastie Posted February 15, 2009 Share Posted February 15, 2009 With my plan to rewire the back half of The Beastie to overcome the endless dodgy earths etc would I be best trying to also remove the original loom to the back or is this likely to be a "Mission Impossible"? Also should I re-wire the trailer socket from the front, or could I hook into connections from the back? It strikes that I am as well doing this whilst I am at it. Thanks for any suggestions Malcy Quote Link to comment Share on other sites More sharing options...
tacr2man Posted February 15, 2009 Share Posted February 15, 2009 It is not that difficult an operation , as you can use the original harness to get a guide string thru , with which to pull your replacement thru . If you have suitable guage wire then the tow plug wiring can be attatched at the rear end. You need to decide from the off which of the two options you wish to go with. HTSH Quote Link to comment Share on other sites More sharing options...
western Posted February 15, 2009 Share Posted February 15, 2009 unplug from front end & then extract the loom from the chassis, wrap it in spiral wrap or convoluted split tubing & cable tie it to the outside of the chassis so it's up out of harms way. Quote Link to comment Share on other sites More sharing options...
