mudmuncher Posted February 15, 2009 Share Posted February 15, 2009 Hi all I thought my rear prop was at fault due to a noise when running so today i removed it and thought i would test drive using only front wheel drive to see the the noise had gone. Good new it had so i need a new reap prop, but the problem is i selected high range 4wd and i had no reverse !!! It drove prefectly in 1,2,3,4, put it in reverse clutch up no drive at all !!! Is this normal do you have to have the rear prop on to reverse ??? Confused Many thanks Chris Quote Link to comment Share on other sites More sharing options...
landmannnn Posted February 15, 2009 Share Posted February 15, 2009 Hi allI thought my rear prop was at fault due to a noise when running so today i removed it and thought i would test drive using only front wheel drive to see the the noise had gone. Good new it had so i need a new reap prop, but the problem is i selected high range 4wd and i had no reverse !!! It drove prefectly in 1,2,3,4, put it in reverse clutch up no drive at all !!! Is this normal do you have to have the rear prop on to reverse ??? Confused Many thanks Chris No, could you have knocked the transfer into neutral when you selected reverse? Quote Link to comment Share on other sites More sharing options...
mudmuncher Posted February 16, 2009 Author Share Posted February 16, 2009 Hi I tried low range and high and had no reverse when the rear prop is on it will reverse in high or low Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted February 16, 2009 Share Posted February 16, 2009 Have you got auto free wheel hubs fitted by any chance. Quote Link to comment Share on other sites More sharing options...
mudmuncher Posted February 16, 2009 Author Share Posted February 16, 2009 I have FWH fitted mayflower type but they were locked as i could drive the landy in forwards gears Would these stop the drive in reverse ?? Cheers chris Quote Link to comment Share on other sites More sharing options...
AdamP Posted February 16, 2009 Share Posted February 16, 2009 AFWH will only lock in one direction like a bicycle hub AFAIK. Tray pedalling backwards on a bicycle and it won't do anything.... Quote Link to comment Share on other sites More sharing options...
HoggyN Posted February 17, 2009 Share Posted February 17, 2009 I have FWH fitted mayflower type but they were locked as i could drive the landy in forwards gears Would these stop the drive in reverse ?? Mine lock in both directions. I'm not sure what type they are though - the naff, leaky type. Quote Link to comment Share on other sites More sharing options...
Rich_P Posted February 17, 2009 Share Posted February 17, 2009 I'm not aware of any free wheeling hubs that only lock in one direction. My MAP hubs lock for both directions with the use of a big spanner. Quote Link to comment Share on other sites More sharing options...
AdamP Posted February 17, 2009 Share Posted February 17, 2009 AFWH will only lock in one direction like a bicycle hub AFAIK. Tray pedalling backwards on a bicycle and it won't do anything.... Done a bit more research, turns out there aren't many of this type left anymore, most AFWH will now unlock and lock in the opposited direction Quote Link to comment Share on other sites More sharing options...
