nokiamutt Posted February 15, 2009 Share Posted February 15, 2009 Ive been restoring a modefied 90 with a 200tdi engine and rad setup , the problem is that the oilpipes have been butchered together to make them fit the oil cooler . Im wondering if there is anyone on the forum with info on where i can get acceptable pipes to use instead of the mess i have on there or should i go and get some fabricated by someone like pirtech etc ? Quote Link to comment Share on other sites More sharing options...
western Posted February 15, 2009 Share Posted February 15, 2009 as you have both ends [metal pipes] you could get Pirtek or similar to reuse these to make new pipes or buy new from LR or Indy LR parts supplier, the correct hoses depend on chassis number, but as yours is a conversion that won't help, unless you know the last 8 digits of the vehicle the engine/rad came from info below should help Quote Link to comment Share on other sites More sharing options...
poohbear Posted February 16, 2009 Share Posted February 16, 2009 Nokiamutt, I have original TD oil pipes in my 90 conversion - you just need to change the unions in the radiator to match. 200Tdi engine - TD oil pipes - TD unions - 200Tdi radiator. Hope that helps. Dave. Quote Link to comment Share on other sites More sharing options...
ciderman Posted February 16, 2009 Share Posted February 16, 2009 I drew a blank matching up the original fittings so I replaced the fittings for 3/8"BSPT (Rad side) and 1/2" BSPP (Hose side) ,and had some 1/2" hoses made up and swaged on to the engine side of the fittings . Cost about half of a genuine set and a better looking job , Quote Link to comment Share on other sites More sharing options...
nokiamutt Posted February 16, 2009 Author Share Posted February 16, 2009 I drew a blank matching up the original fittings so I replaced the fittings for 3/8"BSPT (Rad side) and 1/2" BSPP (Hose side) ,and had some 1/2" hoses made up and swaged on to the engine side of the fittings . Cost about half of a genuine set and a better looking job , Looks very neat and tidy . had new oil pipes made up today , went back to get them , looked ok , went home to fit them .. c&*%s fitted the unions 180deg out and 90deg out ... arse*&%es .. hydrateck in llansamlet .. good price but useless if theyre not right !!!!!!!!! Again Arse*%&es ! The simple looking youngster who served me said casually "no wurries butt come back in an ower " he had a slightly vacant look about him & i now know that my origial fears of giving him the hoses to be right Try again i supose on my next day off . Quote Link to comment Share on other sites More sharing options...
ciderman Posted February 16, 2009 Share Posted February 16, 2009 Looks very neat and tidy .had new oil pipes made up today , went back to get them , looked ok , went home to fit them .. c&*%s fitted the unions 180deg out and 90deg out ... arse*&%es .. hydrateck in llansamlet .. good price but useless if theyre not right !!!!!!!!! Again Arse*%&es ! The simple looking youngster who served me said casually "no wurries butt come back in an ower " he had a slightly vacant look about him & i now know that my origial fears of giving him the hoses to be right Try again i supose on my next day off . Note the yellow markings on the hose and fitting , I brought it all home in peices , Fitted it comfortably and then marked it all , took it all off and back for swaging Quote Link to comment Share on other sites More sharing options...
nokiamutt Posted February 19, 2009 Author Share Posted February 19, 2009 Went back today with a mocked up set of pipes and explained donce again how it needed to be formed and hey presto sorted , the guy used diferent hose that didnt kink and made them in the correct angles . Quote Link to comment Share on other sites More sharing options...
