HoggyN Posted February 24, 2009 Share Posted February 24, 2009 This looks very cool and very simple. The only oil burners I've seen have forced induction. Got any more details/design sketches? Waste oil heaters used to be quite common but you don't see them around these days. I think they must be banned - at least in commercial premises. The simple type I have used looked a bit like the pics below but without the chinese hat on the top. We called it the volcano. The tank at the bottom is filled with oil and then ignited (gas torch) the combustion is kept under control (just) by restricting the air. If too much air gets in they can burn a hole in the roof. In fact, in operation it resembled a buzz bomb engine set on its end. Very entertaining in the wrong hands Quote Link to comment Share on other sites More sharing options...
ebdesignDEFENDER Posted February 24, 2009 Share Posted February 24, 2009 Waste oil heaters used to be quite common but you don't see them around these days. I think they must be banned - at least in commercial premises.The simple type I have used looked a bit like the pics below but without the chinese hat on the top. We called it the volcano. The tank at the bottom is filled with oil and then ignited (gas torch) the combustion is kept under control (just) by restricting the air. If too much air gets in they can burn a hole in the roof. In fact, in operation it resembled a buzz bomb engine set on its end. Very entertaining in the wrong hands the way this heater works is diffrent from theat wich I sugessted.Mine has the oil tank outside the burning area. Quote Link to comment Share on other sites More sharing options...
Mark Posted February 24, 2009 Author Share Posted February 24, 2009 There are some good discussions on oil burning heaters on this thread Quote Link to comment Share on other sites More sharing options...
HoggyN Posted February 24, 2009 Share Posted February 24, 2009 the way this heater works is diffrent from theat wich I sugessted.Mine has the oil tank outside the burning area. Probably a better idea. To be honest, the thing was scary when it running at full throttle. I don't think it was as sophisticated as the one in the picture. I don't remember the damper in the throat of the flue pipe or the return pipe. Quote Link to comment Share on other sites More sharing options...
ebdesignDEFENDER Posted February 24, 2009 Share Posted February 24, 2009 Another ideas Quote Link to comment Share on other sites More sharing options...
dantd5 Posted February 25, 2009 Share Posted February 25, 2009 That is why the chimney has to go outside the workshop! Chris Chris all wrong.- Chimney outside will give you away!! Forgotten about eavesdropping neighbours ? Mr Zroofinders is always sniffing my garden. This is what I use to avoid burning Epos and brake fluid, diesel, GREASE, HYDRAULIC fluids and copper grease But I have lots of wood for export! any one interested? Nice plices (Plices=prices in one country I know of) Quote Link to comment Share on other sites More sharing options...
stravaigin Posted February 25, 2009 Share Posted February 25, 2009 Chris all wrong.- Chimney outside will give you away!! Forgotten about eavesdropping neighbours ? Mr Zroofinders is always sniffing my garden. This is what I use to avoid burning Epos and brake fluid, diesel, GREASE, HYDRAULIC fluids and copper grease But I have lots of wood for export! any one interested? Nice plices (Plices=prices in one country I know of) Dan, sorry but you need to rethink your stove design! that yellow material is unlikely to withstand the high temperatures generated and as it is open on all 4 sides it is inefficient, also your chimney is way too short! Good choice of fuel though. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted February 25, 2009 Share Posted February 25, 2009 Dan, sorry but you need to rethink your stove design! that yellow material is unlikely to withstand the high temperatures generated and as it is open on all 4 sides it is inefficient, also your chimney is way too short! Good choice of fuel though. Stravaigin glad you mentioned that. That yellow bench is PURE Metal and withstands all type-o-heat!! I will elongate the pipes soon!! Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted February 27, 2009 Share Posted February 27, 2009 Chimney outside will give you away!! Forgotten about neighbours ? Cough - http://tinyurl.com/absfl7 Police raided a property after heat-seeking cameras identified a suspected cannabis factory – only to discover nothing more sinister than a wood-burning stove. etc etc The door key they used must have weighed about 14lb, with a long 'shaft'. Of course, once inside they 'might' look for anything else that could justify their attention. HTH Quote Link to comment Share on other sites More sharing options...
