keithjh Posted February 16, 2009 Share Posted February 16, 2009 Hi all, On the wifes 1996 300tdi Disco (Auto edc), a fault appeared this morning it is:- Ligfhts switched onto dipped beam, only lights lit are sidelights, going to main beam, you get main beam indicator, on dash but still only sidelights on vehicle. Any ideas before start ripping things out. Regsrds Keith Quote Link to comment Share on other sites More sharing options...
maxtherotti Posted February 16, 2009 Share Posted February 16, 2009 main culprit would be switch does the main beam flash with lights off?? rob Quote Link to comment Share on other sites More sharing options...
karlo Posted February 16, 2009 Share Posted February 16, 2009 Also check the plugs on the rear of the lights as these tend to overheat and melt. Quote Link to comment Share on other sites More sharing options...
keithjh Posted February 16, 2009 Author Share Posted February 16, 2009 main culprit would be switch does the main beam flash with lights off?? rob no to the above just indication on the dash Keith Quote Link to comment Share on other sites More sharing options...
