white90 Posted February 16, 2009 Share Posted February 16, 2009 Any recommendations? AS the 90 is currently nearly on the floor on lumps of wood after I burnt all the decent sized stuff on the woodburner Quote Link to comment Share on other sites More sharing options...
T1G UP Posted February 16, 2009 Share Posted February 16, 2009 Any recommendations?AS the 90 is currently nearly on the floor on lumps of wood after I burnt all the decent sized stuff on the woodburner got the hd machine mart ones and there high lift 2 tonne trolley jack. http://www.machinemart.co.uk/shop/product/...nds-car-ramps-2 Quote Link to comment Share on other sites More sharing options...
ciderman Posted February 16, 2009 Share Posted February 16, 2009 I favour the ratcheting ones , You cant loose the pins and end up using a screwdriver or an m12 bolt Quote Link to comment Share on other sites More sharing options...
landmannnn Posted February 16, 2009 Share Posted February 16, 2009 Go for as heavy duty as you can afford, even the 6t ones (as previous post) are fairly wobbly on a higher setting. With my previous set I jacked the car up leaving the wheels on and put it on stands, I then succeeded in pushing the car off stands with a hefty shove. I binned that set. I have a 12t pair now which are better, I am still not happy being under the car without also supporting it with a couple of (17t) bottle jacks as well. Quote Link to comment Share on other sites More sharing options...
T1G UP Posted February 16, 2009 Share Posted February 16, 2009 Go for as heavy duty as you can afford, even the 6t ones (as previous post) are fairly wobbly on a higher setting. With my previous set I jacked the car up leaving the wheels on and put it on stands, I then succeeded in pushing the car off stands with a hefty shove. I binned that set. I have a 12t pair now which are better, I am still not happy being under the car without also supporting it with a couple of (17t) bottle jacks as well. never had an issue.....but my bellys not fully formed yet! Quote Link to comment Share on other sites More sharing options...
jakeybaby Posted February 16, 2009 Share Posted February 16, 2009 never had an issue.....but my bellys not fully formed yet! I have two pair of these http://www.northerntooluk.com/products.asp?partno=1470E pricey but when you`re under the motor working away its nice to feel safe and they are rock solid Tim Quote Link to comment Share on other sites More sharing options...
hoarebag Posted February 17, 2009 Share Posted February 17, 2009 We have these:- http://www.toolstop.co.uk/index.php?option...utm_medium=base Very tall and will hold the chassis high and stable enough to alow full droop without needing the pins. Quote Link to comment Share on other sites More sharing options...
andyb Posted February 17, 2009 Share Posted February 17, 2009 I have 4 of those ^^^^. Absolutely brilliant pieces of kit. Quote Link to comment Share on other sites More sharing options...
white90 Posted February 17, 2009 Author Share Posted February 17, 2009 Thanks All I today ordered some British made 6 ton variants with ratchet rather than the screwdriver type ones In the current climate I'm trying to only buy British goods. Quote Link to comment Share on other sites More sharing options...
zulublue Posted February 17, 2009 Share Posted February 17, 2009 Thanks AllI today ordered some British made 6 ton variants with ratchet rather than the screwdriver type ones In the current climate I'm trying to only buy British goods. Good Man Tony. British all the way Quote Link to comment Share on other sites More sharing options...
white90 Posted February 19, 2009 Author Share Posted February 19, 2009 Very pleased with these Cost about £30 delivered. also very stable. Quote Link to comment Share on other sites More sharing options...
landmannnn Posted February 19, 2009 Share Posted February 19, 2009 Nice and solid, you would be better off with a more solid surface though. Quote Link to comment Share on other sites More sharing options...
discomikey Posted February 19, 2009 Share Posted February 19, 2009 i put mine on an old split lorry rim and a big block of wood or breeze blocks and wood mikey Quote Link to comment Share on other sites More sharing options...
white90 Posted February 19, 2009 Author Share Posted February 19, 2009 Nice and solid, you would be better off with a more solid surface though. That's all I have for a Drive though 90 is to tall to go in the garage Quote Link to comment Share on other sites More sharing options...
bishbosh Posted February 20, 2009 Share Posted February 20, 2009 Very pleased with these Cost about £30 delivered.also very stable. Any chance of a link Tony..... Could do with a pair myself..... Quote Link to comment Share on other sites More sharing options...
white90 Posted February 20, 2009 Author Share Posted February 20, 2009 Good old ebay Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 20, 2009 Share Posted February 20, 2009 I use a pile of bricks Les 'squashed head' Henson Quote Link to comment Share on other sites More sharing options...
Dunc Posted February 20, 2009 Share Posted February 20, 2009 Any chance of a link Tony..... Could do with a pair myself..... Mine are almost identical, but 10T ones and red. Superb quality and with a Union Flag on each one. Came from Rimmers a few years back, worth a try to see if they've still got them. Be careful when you're carrying them and you accidentally click the ratchet and the leg goes back in and pinches the bit of skin between your thumb and forefinger in the top of the stand... Ouch. Quote Link to comment Share on other sites More sharing options...
Mr Alford Posted February 23, 2009 Share Posted February 23, 2009 draper tools do some very good hgv stands Quote Link to comment Share on other sites More sharing options...
PaulN Posted May 9, 2009 Share Posted May 9, 2009 Very pleased with these Cost about £30 delivered.also very stable. I would like to follow suit in every respect - but which British make are they please? Quote Link to comment Share on other sites More sharing options...
