Roll Cage Paint
Yellow Hammerite smooth would do, surely?
Either that or farmers machinery suppliers (or Mole Valley does as well IIRC) will almost certainly have 'John Deere Yellow' or 'JCB Yellow' which is cheap as chips and hard as nails :)
Smooth Hammerite is quite brittle and chips badly, will still need a primer to be done properly.
Tractor paint would be a good idea, although a primer will still be needed.
I'd still powdercoat, did my cage in two colours, red and yellow.
Cheers
David
dont powder coat it as any tree rubbing etc and it will crack off with time then you will be stuck!
Mole Valley farmers or equivalent tractor paint with appropriate primer worked very well on mine and cheap too
