Headlight relay
hi,
i am in the prosess of wiring up 2 wipac 100w driving lights, and i have wired up everthing, accept i need the wiring diagram of the full beem relay,with the numbers of the legs. as i am planning on taking the positive from the full beem relay(it dosent matter which one, but i was thinking the "output"leg) to power my wipac relay,
thx
Stan
just splice it into the main beam wire, it'll do exactly the same function as being at the relay & will be a much shorter run of wire as well.
yeh, i intended to do that, but when testing for the main beem feed, we blew the diped beem fuse :blink:
so i thort i could crimp a conector which pluged into the relay,and then the main beem bluged into that, so i wouldent have to cut anything,
thx
hi,
thx
Stan
Whereabouts is your relay situated?
You could tap into your high beam indication on the dash. You are looking for a blue w white tracer i would have thought.
Any help??
Relays on all high power ccts such as headlights horn etc are always a good idea.
Cheers.
 Share
