Megansfolly Posted February 18, 2009 Share Posted February 18, 2009 its a disco 200 tdi i ve take the boost actuator off and i am having problems gettin the new onr on and lined up, looking on net my turbo exit is atthe wrong angle? pic below shows it compared to this pic i found on net Quote Link to comment Share on other sites More sharing options...
disco_al Posted February 18, 2009 Share Posted February 18, 2009 isn't that a disco lump? the defender turbo is mounted higher up IIRC. Quote Link to comment Share on other sites More sharing options...
Eightpot Posted February 18, 2009 Share Posted February 18, 2009 It's possible to rotate the ally bit to make it easier to connect the I/C pipe on when you have a disco engine in a defender - looks like it's been rotated. Quote Link to comment Share on other sites More sharing options...
Megansfolly Posted February 18, 2009 Author Share Posted February 18, 2009 sorry about that yes its a disco lump in a defender i took the actuator off as i bent it the new one, seems at a funny angle then i did some research on net and it looks to me like the turbo outlet is pointing down wards when it shouldnt be Quote Link to comment Share on other sites More sharing options...
Megansfolly Posted February 18, 2009 Author Share Posted February 18, 2009 sorted i think i ll see if turbo ally part can be knocked round a bit http://forums.lr4x4.com/lofiversion/index.php/t2049.html engine fell over and didnt think it had done any damage but i may have done now looking at it Quote Link to comment Share on other sites More sharing options...
poohbear Posted February 18, 2009 Share Posted February 18, 2009 I have just put a Disco Tdi in my 90 - the turbo outlet is at the same angle as the one in your second picture. I just cut a hole in the inner wing to give me some more room for the 90' elbow. This has allowed me to fit the bottom intercooler pipe in a straight run under the original air box. Dave. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted February 18, 2009 Share Posted February 18, 2009 I have just put a Disco Tdi in my 90 - the turbo outlet is at the same angle as the one in your second picture. I just cut a hole in the inner wing to give me some more room for the 90' elbow. This has allowed me to fit the bottom intercooler pipe in a straight run under the original air box. Dave. Likewise. If you do rotate the housing you will have to fabricate a new mounting bracket for the actuator arm. Either that or drill and blind tap the ali casting....... Quote Link to comment Share on other sites More sharing options...
