Tear it up Posted February 19, 2009 Share Posted February 19, 2009 Started work on salisbury rear drum to disc conversion today. After getting a bit carried away with a seized bolt and a very large lump hammer I seem to of damaged the drive flange . I've placed an ad in the wanted section but don't hold much hope that someone's got one lying about, so has anyone got any suggestions as to the best place to get one apart from land rover themselves? Also would like to check the diff ratio as can't seem to see it stamped in the diff. Other than counting the teeth on the crown wheel and pinion, is there a way of telling and where should I be looking? Quote Link to comment Share on other sites More sharing options...
western Posted February 19, 2009 Share Posted February 19, 2009 all 90/110 use 3.54:1 diffs as do RR & Discovery. any of the drive flanges will fit, front & rear on 90/110 are common, but later Defenders use a thinner flange. any of the usual parts suppliers can source one for you. Quote Link to comment Share on other sites More sharing options...
