draper40 Posted February 20, 2009 Share Posted February 20, 2009 Hey, There is oil coming out of the joint between the propshaft and the diff, is there an oil seal in this joint to replace? Thanks Pete Quote Link to comment Share on other sites More sharing options...
The Novice Posted February 20, 2009 Share Posted February 20, 2009 This may answer your question. http://www.roversnorth.com/store/c-160-differential.aspx Quote Link to comment Share on other sites More sharing options...
markyboy Posted February 20, 2009 Share Posted February 20, 2009 Hi Pete, As has already been pointed out by "The Novice", there is a diff pinion oil seal. Easy enough to replace with a bit of knowhow and the right tools, but sometimes it's also necessary to replace the drive flange as it can have a groove worn in it from the oil seal. You can see from the exploded diagram in the link it's a simple case of removing the prop-shaft, undoing the pinion nut, pulling the drive flange off the pionion shaft then levering the old seal out before fitting the new seal and repeating the disassembly process in the reverse order. It's a case of stripping it and having a look then ordering the parts required. Hope this helps. Mark Quote Link to comment Share on other sites More sharing options...
draper40 Posted February 20, 2009 Author Share Posted February 20, 2009 Item 27 on the diagram? Thanks Pete Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 20, 2009 Share Posted February 20, 2009 Replacing a diff pinion oil seal. http://forums.lr4x4.com/index.php?showtopic=7903 Les. Quote Link to comment Share on other sites More sharing options...
markyboy Posted February 20, 2009 Share Posted February 20, 2009 Item 27 on the diagram?Thanks Pete That's the one. Mark. Quote Link to comment Share on other sites More sharing options...
