Mapolo Posted February 20, 2009 Share Posted February 20, 2009 hello I need help I`m about to buy a nanocom but i need to know if I can replace and injector using the nanocom and been able to program the new injector tho the ecu uding the nanocom Thanks so much. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted February 20, 2009 Share Posted February 20, 2009 Welcome Yes I understand you can do this with Nanocom though I've not actually tried it first hand. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 20, 2009 Share Posted February 20, 2009 You might get away with disconnecting the battery, replacing the injector, then reconnecting the battery. This is the trouble with people living on a rock in the middle of the south Atlantic giving advice (they still bash things with rocks y'know) Nanocom will sort it if the battery thing doesn't work. Les Quote Link to comment Share on other sites More sharing options...
BogMonster Posted February 20, 2009 Share Posted February 20, 2009 You'll need to somehow reprogram the injector grades into the ECU, that is for sure, unless you happen to get an injector exactly the same which is unlikely. I'll bash you with a rock in a minute Henson Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 20, 2009 Share Posted February 20, 2009 Quote Link to comment Share on other sites More sharing options...
cipx2 Posted February 20, 2009 Share Posted February 20, 2009 Mapolo, have a look at these threads for other questions you might have reg Nanocom and injectors: http://forums.lr4x4.com/index.php?showtopic=36204 http://forums.lr4x4.com/index.php?showtopic=33077 http://forums.lr4x4.com/index.php?showtopic=28135 http://forums.lr4x4.com/index.php?showtopic=27523 By the way, welcome to the forum, which is not only a forum but also a database. This means search first, search again, search some more and don't ask if you can't find what you're looking for Edit: forgot to give you the clue: http://www.google.com/search?num=100&h...ite%3Alr4x4.com Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 20, 2009 Share Posted February 20, 2009 I never use the search function - it makes the rest of the members lazy. Les Quote Link to comment Share on other sites More sharing options...
Mapolo Posted February 25, 2009 Author Share Posted February 25, 2009 I never use the search function - it makes the rest of the members lazy. Les thanks so much for all your help. I´ll wait for my nanocom and try it with the inyectors and then I´ll post my findings Quote Link to comment Share on other sites More sharing options...
