Megansfolly Posted February 23, 2009 Share Posted February 23, 2009 i ve finnished my disco 200tdi in to a defender converstion now have a similar steve parker down pipe and thats it at moment. the id of the down pipw is 55 and od is 57 mm i ve looked around and done some searches on here and not come up with alot, so any advice do i bit the bullet ans ahve a a system build for it, or flexi pipe and a cherry bomb? is there a max db rating for an exhaust does it have to exit at a certain place? Quote Link to comment Share on other sites More sharing options...
Eightpot Posted February 23, 2009 Share Posted February 23, 2009 its easy enough to use a standard LR exhaust - I found that the late 300TDi exhausts fit well. They are pretty wide bore - about 2.5" I think, so breathe nicely. I used an esr2297 front pipe, then chopped of the manifold/turbo end to mate up to the Steve Parker downpipe - means you don't have to muck about making a connector up and getting flanges etc. Costs about £21. Then a centre silencer ESR4526 - £75 (or you could use a straight through conversion pipe for about 40 quid) and a tailpipe ESR4527 (about £35) Only bit I had to modify was the centre exhaust hanger as the silencer sat further back than on my n/a exhaust - just made up an extension with some 1" angle iron and job done. Quote Link to comment Share on other sites More sharing options...
