Replacemet light fluid
TimR
If you have clear lense indicators with the orange bulbs, then headlamp fluid won't work as headlamp fluid is clear. Headlamp/sidelight/reverse/number plate fluid is the same P/No, as are tail/stop and rear fog lamp fluid. Early model indicators can use the same fluid as headlamp, etc, but later models need the correct orange fluid.
Les :)
If you have a TD5 you need nanocom or a trip to the dealers to reset the ECU with the new fluid code.
On the Puma model you need Landrover special tool LRS4587 to relieve the pressure while filling to prevent airlocks in the system.
Tim, I think that's the old part number, there's a one shot version available now, you'd be forgiven for thinking it looks like thick muddy water but when it gets warm it thins out and has the advantage that it won't leak out of the light seals when cold.
