Traco Posted February 24, 2009 Share Posted February 24, 2009 My D1 V8 auto gearbox to oil cooler hoses are leaking where the rubber is crimped to the metal pipes. Are these pipes replaceable individually or in a kit? Or can the pipes be cut and high pressure oil cooler hose be inserted and clamped on to the pipe ends with jubilee clamps? Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted February 24, 2009 Share Posted February 24, 2009 Get the pipes made up by a proper hydraulics place. That's what we do with the 300Tdi oil cooler pipes - the OEM LR ones are expensive and useless. Quote Link to comment Share on other sites More sharing options...
ciderman Posted February 24, 2009 Share Posted February 24, 2009 You have a choice , you can get new hose swaged onto your existing pipes or have the whole lot replaced with new complete hoses . Its a job I have just done on my defender , The pipes are 1/2" the fittings are 1/2" BSP 90 deg , the gearbox and cooler adaptors are 16mm >1/2"BSP Dont forget you may have a temperature warning switch in one of the pipes so this will have to be taken into consideration , Mine is to be mounted in the gearbox sump . All hoses in pics are in an un-swaged state whilst getting the distances and angles right . Quote Link to comment Share on other sites More sharing options...
