sotal Posted February 24, 2009 Share Posted February 24, 2009 Just been asked and I haven't got a clue! Does anyone know if the td5 crank can be re-ground? Something to do with it spinning a shell (all a bit beyond me but I said I'd ask on here) Or is it a throw away and replace item? Are they expensive? Quote Link to comment Share on other sites More sharing options...
cipx2 Posted February 24, 2009 Share Posted February 24, 2009 It can be reground one time - 0.25 mm. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 24, 2009 Share Posted February 24, 2009 If it's worn beyond the limit, then weld spray and regrind to original spec is another possibility. Les. Quote Link to comment Share on other sites More sharing options...
sotal Posted February 24, 2009 Author Share Posted February 24, 2009 Thanks, I've managed to find a bit of information which said it is coated with something to make it harder, one regrind is ok like cipx2 says. It did mention welding then regrinding to original but it then needs coating again Quote Link to comment Share on other sites More sharing options...
