russ1 Posted February 24, 2009 Share Posted February 24, 2009 Hello People I have a 2000 vogue and the cd changer has given up! after doing a google search i have found that theres a common fault on these changers. Does anyone know if theres a different model changer i could use? The model that i have is a alpine xqe100240 is there any others i could use? It has the square connector on the changer. Many thanks Quote Link to comment Share on other sites More sharing options...
vougese39 Posted February 24, 2009 Share Posted February 24, 2009 Hello PeopleI have a 2000 vogue and the cd changer has given up! after doing a google search i have found that theres a common fault on these changers. Does anyone know if theres a different model changer i could use? The model that i have is a alpine xqe100240 is there any others i could use? It has the square connector on the changer. Many thanks mine failed in my classic and i was able to get it repaired some radio fitting shops still have arepair area mite even be worth talking to apline direct? Quote Link to comment Share on other sites More sharing options...
Chris_944 Posted February 27, 2009 Share Posted February 27, 2009 You should be able to fit any Alpine changer I would have thought and possibly some other makes too. Best thing to do would be to nip into a local audio shop. They are usually really helpful... Probably cause they want to get you spending your dough there lol Quote Link to comment Share on other sites More sharing options...
