poohbear Posted February 24, 2009 Share Posted February 24, 2009 Hi all, can somebody tell me what bolt should be in the flywheel housing inpsection hole - might be going swimming this weekend and wanted to make sure the bits that need to stay dry do! Its a TD flywheel housing if that helps Also need to fit a breather/drain as the original drain hole is now blocked by the crankcase on the Tdi! How easy is it to drill and tap a hole in the bottom of the housing without destroying the starter teeth on the flywheel or filling the housing with swarf? Dave. Quote Link to comment Share on other sites More sharing options...
western Posted February 24, 2009 Share Posted February 24, 2009 it's a taper thread IIRC, the LR part is 3290 same as fitted in the TD engines timing case drain hole. the 200Tdi uses a hex head with a flange ERC7295 & also used to seal the flywheel housing drain. Quote Link to comment Share on other sites More sharing options...
poohbear Posted February 24, 2009 Author Share Posted February 24, 2009 Thanks Western. will look to getting one on order. D. Quote Link to comment Share on other sites More sharing options...
