Cv joints, and drilled and groved discs.
muddychris300tdi
Thanks i thought i would get more stopping power with drilled and grooved.
I may be wrong but I believe that a comment in a previous thread suggested that they would just clog up with mud?
These were an on road mod for uprated RRs so it would make sense I guess.
Hi i need to change my cv joints 24 spline on my disco, are brit part ok in this area or should i use another make? And while its all off i want to change my front discs for drilled and grooved, looking at the ebc ones from paddocks. Are these ok or should i use another make? Chris
if you plan to take the truck off road don't buy the drilled/groved ones from paddocks. had them on my challenge truck and the wholes/grooves filled with dirt that wasimmpossible to remove and that wore the pads in no time. standard ones are much better for off road use.
