kbeaton1972 Posted February 26, 2009 Share Posted February 26, 2009 Hi in need of help, my Range is not starting its to do with the cold start i've been told.... i messed up the wires or should i say some one else did, the wire that's to do with the cold start not sure where it goes, i put it straight on to the coil... been told thats my problem!!! it only runs for 20 seconds but from cold it runs for about 2 min. has any body got a picture of the wires coming out of the coil?? so i can see where they all go.....thanks Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 26, 2009 Share Posted February 26, 2009 - What year - What engine - Carbs or EFI - If it's EFI is it Flapper or Hotwire (the search button will explain the difference) - What "cold start wire"? What colour(s) is it and where does it go? Quote Link to comment Share on other sites More sharing options...
kbeaton1972 Posted February 26, 2009 Author Share Posted February 26, 2009 - What year- What engine - Carbs or EFI - If it's EFI is it Flapper or Hotwire (the search button will explain the difference) - What "cold start wire"? What colour(s) is it and where does it go? 1988 3.9 efi the wire is a blue and white it goes to a little box thats bolted to the bottom of the air flow metre moulting... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 26, 2009 Share Posted February 26, 2009 The blue/white wire is the tach signal to the ECU, the fact it runs at all suggests it's connected right. It should be on the coil -ve. Quote Link to comment Share on other sites More sharing options...
steve_d Posted February 26, 2009 Share Posted February 26, 2009 The blue/white wire is the tach signal to the ECU, the fact it runs at all suggests it's connected right. It should be on the coil -ve. HFH Does that year of 3.9 have the over-run cut off relay as that may be the box the OP is referring too? Sounds to me like a gummed up stepper idle valve. Steve Quote Link to comment Share on other sites More sharing options...
